Bench Top Power Supply — Parallax Forums
NWCCTVNWCCTV Posts: 3,629
edited 2012-11-30 16:31 in General Discussion
Can anyone recommend a bench top power supply in the $150.00 range?
    edited 2012-11-29 20:20
    Be wary of power supplies that have digital readouts but are not digitally controlled. They are hard to adjust with any precision, and they will drift. I bought a cheap Chinese-made PS awhile back and learned the hard way. What's worse, I have to disconnect all the leads before I turn it off, because the voltage output spikes during shutdown.
    Stick to known brands like B&K Precision or Extech, and you should not have a problem.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-11-29 20:22
    Great. Thanks for the info. Any on that site you would recommend Phil?
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-11-29 20:32
    Buy a used Lambda or HP on EBAY.
    Duane J
    edited 2012-11-29 20:34
    I've used elenco brand before.
    I am currently using this one:
    http://www.kitsusa.net/phpstore/html/HY3005D-3-MASTECH-Triple-Output-Variable-DC-Power-Supply-Digital---2X-0-30V0-5A-1X-5V3A-DC-6179.html
    You might pick a couple of these model numbers then search the internet for reviews.
    edited 2012-11-29 20:44
    I wish I could make a positive recommendation, but I can't, since I have no experience with any but one of them, namely:
    http://www.kitsusa.net/phpstore/index.php?l=product_images&p=6179
    I'd stay away from it for the reasons noted. Plus, the inside of it is just scary.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-11-29 21:42
    At work, we have bunches of MPJA bench supplies that work fine as long as you're aware of the issues. For cases where we need more precision and consistency, we use gw-instek, but that's probably not within your $150 range.
    SparkFun sells one for $260 (https://www.sparkfun.com/products/9291) that they rave about. I have no personal experience with it, though.
  • idbruceidbruce Posts: 6,197
    edited 2012-11-30 01:11
    @NWCCTV
    In another thread, you were discussing power distibution boards. Does this have anything to do with that? If so, I am just wondering why you just don't create one. Of course, there are obvious reasons, but if you just need known voltages, with the ability to handle a specific amount of current, then there are a couple routes to go besides buying a manufactured unit. You can also make small variable power supplies pretty easily.
    What are you going to do with it? Depending on the project, there are times when a linear power supply is a better choice, as compared to a switch mode power supply. For instance, if you providing power for motors, then linear is most likely your best bet.
    I personally find power supplies very interesting, especially the linear type, because they are simple to make :) Switch modes are way over my head, so I will leave them to the pros. Transformers are everywhere... Most electrical devices contain some type of transformer, and I always salvage them when junking something.
    I know I have this in another thread, but this is one of my all time favorites. I did not create it and I forget the source, but I am including it here, just in case someone else likes the idea. Just add transformer :)
    All linear power supplies have the same basic make up and theory, at least to my knowledge.
    Bruce
    EDIT: Additionally, PC power supply units provide a wide array of voltages, if wired correctly, you can even get 24V out of them. There is a lot of information on the internet about converting PC PSUs to benchtop power supplies, for example, here is a link (I am not endorsing this articles accuracy) http://web2.murraystate.edu/andy.batts/ps/POWERSUPPLY.HTM
  • xanaduxanadu Posts: 3,347
    What voltage/amp range are you looking for?
  • TonyDTonyD Posts: 210
    edited 2012-11-30 02:35
    I've got one of those, There OK-ish. They only have one pot for the voltage so it feels a bit over-sensitive when trying to set the voltage and the current sense stop working in mine after 12-months :-(
  • BeanBean Posts: 8,129
    edited 2012-11-30 05:33
    I have a couple of the $90 Lascar PSU130 units.
    http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_301971_-1
    Nothing fancy but they seem to work well for what they are.
    The only thing I don't like is that the minimum voltage is about 1.2V not zero. And there is no current limit setting.
    Bean
  • Paul Sr.Paul Sr. Posts: 435
    edited 2012-11-30 05:58
    I have been using a product called "ATX Breakout Board" - a Dangerous Prototypes piece available at Seeed. Just plug it into a PC Power supply and go! It's pretty nice for a non-adjustable power source. If you need more precision or something adjustable, then it may not be for you.
    http://www.seeedstudio.com/depot/atx-breakout-board-bench-power-supply-p-1222.html?cPath=155
    edited 2012-11-30 07:04
    @Paul Sr.
    I like it!!!!!!!!!!
    I think a lot of things can be done with that breakout board as a principle idea. Extremely cool and ingenious. Just make a PCB with the desired circuitry and plug in a PC PSU. Very, very cool.
    Thanks for sharing.
    Bruce
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-11-30 09:11
    You can sometimes find good deals ($100-$200) on HP/Agilent E36XX series units on eBay. Not a bad choice if the the voltage /current range fits your needs. BK Precision is also good. For simple needs, just build one with an LM317. You can add a 7660 and an LM385 or similar and get close to zero volts if you really need it. Current limiting can be done but it's a bit more complex.
  • Don MDon M Posts: 1,654
    edited 2012-11-30 14:42
    I have a pair of these on my bench. I've had great luck with them. You might find some on Ebay.
    http://www.web-tronics.com/programmable-bench-power-supply-csi3645a.html
    edited 2012-11-30 15:05
    idbruce wrote: »
    @NWCCTV
    No, The PDB is for a robot. I have considered building one from a computer PSU. However, I am busy and just want a good one for running my experiments with and I was also going to put it on my Christmas "want" list. I am also getting a solder station but was advised to stay away from the All In Ones.
    edited 2012-11-30 15:07
    xanadu wrote: »
    0- 36V or 50V and to about 3 AMP.
    edited 2012-11-30 16:19
    Still going with my Heathkit triple supply, 5v fixed and two 0-26v that can "track"
    FF
  • Mark_TMark_T Posts: 1,981
    I've an old instek ps-3030 (32V, 3A) with analog meters and its done great service, seems bomb-proof. The newer models (gps-3030) have digital meters of course
    but look the same arrangement, fine + coarse for both current limit and voltage, 2 current ranges (1.5A, 3A). Nice big on/off button that's easy to find in a hurry!
