Abz encoder
Hi
I´m making a project to measure distance using an ABZ encoder (incremental) and I have checked the wiring diagram publicated on the web page for the easy encoder, but this sensor has 2 lines for power, A, B, Z lines for signal, so the connection is different and I have a lot of doubts how to connect this in my BS2.
I don´t want to damage the sensor.
Could you help me??
Could you help me??
However, in general terms, the unit will need power: (usually red and black wire or brown(+) and blue(-). Many are OK from 5 - 30 VDC, but there are also quite a few that are 5 volt only.
The signals A and B are the quadrature pulse outputs and the ones you'll use. Z is often a "once per revolution" pulse sometimes used for homing or calibration.
In my case, black and white are for power supply....0V and 24V respectively; Red, Green, Yellow ....are for signals A, B and Z respectively.
I have checked the wiring diagram for the incremental rotary encoder that is published in parallax web page, but I can not connect like that because it has only three terminals A,B and C.
So my question is how to connect the encoder.
Thank you very much guys for your replies and help.
Cheers,
Thank you very muc for your help!! I will do it!!
