Servo with Propeller
Is anyone aware if I can control my hitec micro servo off of the propeller proto board? I read the specs on the servo and it says it operates on a 4.8v-6v; however, everything Ive read that the propeller chip can only run servos off of a stand alone servo controller.
Any help would be greatly appreciated!
Taylor
Taylor
I'd put a 2k2 resistor in-line with the signal line, and make sure you power the servo off 5V
I've run a lot of servos and sensors at the same time from a prop... see http://mikronauts.com/roboprop/
And whenever servos are mentioned together with Propellers, that's my cue to point out my 32 servo demo and my QuickStart servo tester.
-Taylor
