Write and read eeprom — Parallax Forums
dardar Posts: 15
edited 2012-11-27 13:36 in Propeller 1
Hi
I'm new with .spin and propeller. I'm trying to write and read in a 24LC256 external eeprom, the same eeprom where is the Objects. Can I write there? or I need use another external eeprom?
And can you help me with the object i need and the code?
    edited 2012-11-25 10:55
    There's a tutorial for reading a writing to EEPROM here.
    This is the BASIC Stamp forum. This is a question better asked in the Propeller Forum.
    Unfortunately we can't delete threads we accidentally start so you'll want to be careful about starting multiple threads. It is possible to edit a post though. So if you don't like the way a post was worded, you can edit it.
    edited 2012-11-27 12:11
    I will move this thread to the appropriate forum.
  • RaymanRayman Posts: 16,033
    Are you using a Propeller chip dario? If so, check out the "OBEX" and I think you'll find several objects...
    The one I often uses is called "Propeller Eeprom.spin".
