Write and read eeprom
Hi
I'm new with .spin and propeller. I'm trying to write and read in a 24LC256 external eeprom, the same eeprom where is the Objects. Can I write there? or I need use another external eeprom?
And can you help me with the object i need and the code?
This is the BASIC Stamp forum. This is a question better asked in the Propeller Forum.
Unfortunately we can't delete threads we accidentally start so you'll want to be careful about starting multiple threads. It is possible to edit a post though. So if you don't like the way a post was worded, you can edit it.
The one I often uses is called "Propeller Eeprom.spin".
