Propstick Crystal
I'm looking at the Propstick USB schematic and I see that the 5 MHz crystal is connected between the XO and XI pins on the Prop. Below that I see that the Prop's XO pin is labelled NC (No Connection, I 'spose).
Hmmmm...
But my question is actually this: If I wanted to run a Propstick from a single-ended 5 MHz oscillator instead of a crystal, what would be the correct way to connect it?
Thanx for reading my post.
Tim
Hmmmm...
Tim
There seems to be a discrepancy in the schematic that I never noticed before. The section for just the crystal shows a connection to XI and XO, but on the chip, XO is not connected.
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32210-PropStickUSB-1.2.pd
XO can be left disconnected depending on the CLK Register settings. (Page 28-29)
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/Web-PropellerManual-v1.2.pdf
EEPROM: This chip is rated for -40F. But it's only used at startup...I'm not logging any data. I'll use it and pray that it works at -50F, in case this product ends up in, like, Antarctica.
XTAL: I can't find a 5 MHz crystal that claims to be good at -50F, but I can find lots of 10 MHz oscillators that do. I can divide it by two with a 4013 and, according to the above, inject it into the IX input. BTW, most TTL chips only claim to work above 32F...
FT232: No problem, offboard programmer.
OTHER: Dunno. Build and test, build and test, repeat as necessary.
Does anyone see any potential potholes here?
Thanx.
BTW, I am not a Parallax employee.
I can attempt to answer the question about the 10MHz oscillator. A 10 MHz on XI should work just fine with a PLL of X8 (80 MHz). Been used many times.
I can't answer the questions about the cold temps. My installs have been in more friendly environments.
The specs on the Propeller USB are:
Operating temp range: +32 to +158 °F (0 to +70 °C)
BTW, the "NC" in the PropStick USB schematic is definitely a misprint. It should be labeled "XO".
You as well. I'm stuffed....:)
Phil,
I checked the Diptrace layout, and I don't see a trace going out to Pin 31 on the Prop-USB. X0 does go directly to the Prop pin 29
You'r correct Phil, I was just trying to convey that information to the OP per his original message. I also did not understand why the X0 was not brought out to Pin 31
Great info as always. Thanks!
Jim
CON
_xinfreq=80_000_000 'use external 80 MHz oscillator
_clkmode=XINPUT 'use external 80 MHz oscillator
and it'll work?
In a way, it is specsmanship. Even if a given crystal would most likely start up fine and operate at -55°C, its -40°C rating may be the crossover point for +/- 30ppm stability. AT cut crystals have a cubic temperature dependence. The crystal rated to for the wider temperature range may be speced at +/-100ppm stability over temperature. Of course there may be other issues having to do with operating temperature range, for example how the crystal is packaged. You'd best go into it with a call to the crystal manufacturer.
ECS-080-20-4X-DU
D : +/-100ppm
U : -55 +125°C (operating temperature is implied but not stated)
Digikey also carries the ABLS-5.000MHZ-L4Q-T in HC49 (smt style)
L : -55 +125°C operating
4 : 30ppm at 25°C
Q : 100ppm over range
Even after rereading the datasheet, I'm not sure what to make of the discrepeancy between the "Operating Conditions" and the "Custom Options." I'm sure you're correct, and maybe it's just a matter of post-production binning, But, as you recommend, I would definitely contact the manufacturer before committing to that crystal.
