Your ESD foam, becomes a Quickstart board.
Oldbitcollector (Jeff)
I've been pricing ESD form lately. Did you know that the pricing on that stuff is obscene?!
Best price I've found is $4.00 for a 4"x4" square! Gheesh!
I'll bet a bunch of you have a piles of this stuff laying around....
Before I place an order for a bunch of this, if someone here would like to turn 25" square inches of the stuff into a Quickstart for your shop, leave a message on this thread. I don't care if it's in pieces as small as 2"x2" (as long as it's clean and in "like new" condition.) I'll accept both PINK (static resistant) and BLACK (anti-static),
edit: needs to be thick enough to seat a DIP (around 1/4").
I'd rather toss a FREE Quickstart someone's way than dump a few more dollars in someone else's pocket!
(Propellerpowered.com is YOUR store, not theirs!)
Jeff
Jeff
http://www.correctproducts.com/ESD-Packaging/High-Density-Black-Conductive-Polyethylene-Foam/High-Density-Black-Conductive-Polyethylene-Foam_2
Made in the USA too!
Wanna trade one 24 x 36" sheet of it for 34 QuickStarts?
Offer stands.. If some here has 25 square inches of it, I'll be happy to swap you for a new Quickstart.
Jeff
Edit: BTW, the secret plan is working.. Figured I'd give away one Quickstart in exchange for someone's stored foam and someone would post a good source for when I run out.
Let me know!
Amanda
Mission accomplished. 1) Solved immediate supply issue while doing something nice in return! 2) Tuned into solid source for restock!
Love this group!
Jeff
The brainettes started through the store room, and started digging out every piece of foam. The lab gnome says the pinks stuff SHOULD be ESD, but how do we check for sure?
i shall do some tests when i get back to the bench!
I'm using this when you guys order chips.
Be sure and have "return addresses" in those packages so I know where to send the reward to.
Thanks!
Jeff
Jeff
