Optical flow sensor for odometry and altitude hold
Did you see this board from dihydrones.
They used it on drones for X,Y position hold.
Then the measures are combined with other sensors.
May be useful for bots odometry ? If i remenber well it has been used .
http://store.diydrones.com/Optical_Flow_Sensor_p/br-0016-01.htm
Jean Paul
Jean Paul
I was planning on trying this with a mouse sensor kit but I was very unsure about what kind of lens I'd need. This makes using the sensor much easier.
@rwgast, yes, they using a different lens so the mouse sensor can work at a greater distance than normal.
i think the best thing is if u center this under a 3 wheel bot it can track distance just like a wheel encoder but if you do perfect 180 turns you wont be adding values to your distance calculation like you would with wheel encoders, but i guesswith a wheel encoder you could stop counting pulses in a turn...
so whats a unique use for this if your using encoders
I've also read that using a mouse for odometry isn't as accurate as encoders but I I'm not sure if this if correct or not.
If you calculate the distance travelled by averaging the encoders then a 180 turn (pivot) will add no distance.
