Programmable Scrolling LED Name Badge — Parallax Forums
ozarkshermitozarkshermit Posts: 14
edited 2012-11-18 07:05 in General Discussion
Hi
Does anyone know where to get some of the cables used to program these (7 x 29 scrolling LED badge)? The cable has a standard USB on one end, the other is a "Sub-Micro" size USB male plug. The plug is approximately 5.5 MM wide by 3 MM thick. I read somewhere that these are a proprietary cable, but find it hard to believe the ChiComs would not use some "off the shelf" cable. The plug ends both have the standard USB Triad type logo. I'm hacking some of these signs, and would rather just buy the badges, rather than badge, cable, and CD, if I can find cables cheap enough.
TIA
Ken
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-11-17 07:36
    You have to give us a bit more:
    A link would be best.
  • dgatelydgately Posts: 1,641
    edited 2012-11-17 11:26
    Check this page on Wikipedia for possible connector types: http://en.wikipedia.org/wiki/Universal_Serial_Bus
    Seems like it might be a USB-micro (versus USB-mini) connector. The RaspberryPi uses this type of connector/cable for power...
    dgately
  • ozarkshermitozarkshermit Posts: 14
    edited 2012-11-17 11:55
    Thanks - I had checked wikipedia earlier, and this connector is smaller than anything shown. I'm starting to believe that it is indeed a proprietary connector. I guess they sell enough of the badges that it was worth their while to develop their own connector. I am trying to buy just some cables from some of the vendors - probably a hopeless cause however.
    Ken
  • Mark_TMark_T Posts: 1,981
    edited 2012-11-17 17:17
    If the plug dimensions you give are accurate then its neither mini USB nor micro USB I'm afraid... mini is 6.8x3.1 and micro is 6.8x1.8, as I've just measured.
    edited 2012-11-18 06:01
    Thanks.
    I measured the plug with a digital micrometer, so the dimensions are accurate. I am now convinced this is a proprietary plug - I asked to purchase just some cables but probably won't succeed. These are really nice, small Led Matrix signs, I hope to hack some to be able to program them without using a PC, rather directly from a PIC, that way I should be able to send a variable (temperature) to them and display it along with a message.
    Here is a link that "sparked my curiosity" for these.
    http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.digitalspirit.org%2Fwiki%2Fprojets%2Fledmatrixhacking
    It is originally in French, but the link has the Google translator included. He states that the plug is proprietary, I guess I was hoping he was wrong. He is wrong on one thing though, regarding his statement that the sign could not be programmed via the cable. I originally purchased one with the cable and software, and then some others without the cable and software. They all program OK. I purchased two them from the ebay site I linked to earlier, and one other from another seller. I have opened one of them up, and hope to be able to solder two wires to where the usb is connected. There are only 4 connections, +, -, D+ and D-. They run fine just off the USB cable, using power from the port (don't need the LiIon battery). I plan on connecting my Logic Analyzer to D+ and D-, and interpret the protocol used.
    Ken
    edited 2012-11-18 06:09
    By the way, I would like to point out that I am using a standard PIC, and programming it in PicBasicPro, which is very close to the Stamp software.
    Ken
    Cool idea. As long as you're hacking to input the data, consider some of the cheaper $9 units which have no usb input, just 3 pushbuttons on the back. You could hack those switches and write code to bit bang directly into them.
