Where do I buy Litz Wire
I would like to build an induction cooktop for myself. The one challenge, as far as locating part is the Litz Wire for the heating surface. I can only find companies that sell it by the Km. Anyone know where I can find smaller amounts?
...are you SURE you want Litz wire??? For an induction heater? Errrr..............
http://en.wikipedia.org/wiki/File:Induktionskochfeld_Spule.jpg
What kind of frequency are you looking at? voltage and current?
This looks really interesting.
interesting use of Litz . I had a senior over last night advising him on his final project . Wireless I pod chager
http://www.element14.com/community/events/3466 was the base Idea He is going off from . but both a iduct heater and the charger has a ton in common .
some CRT necks are also known to use litz .
Peter
http://inductionheatertutorial.com/
It has been over 50 years since I played with an Litz wire, but as I clearly remember ... it is not easy to solder. Connections might best be made by mechanical means. Removing the insulating enamel is tricky.. maybe use a torch to burn it off or strong solvents.
I suppose you could go the other direction and salvage Litz wire from an old metal detector. You might also salvage it from a CRT deflection yoke or a flourescent ballast.
http://www.elektrisola.com/litz-wire.html
