Where do I buy Litz Wire — Parallax Forums
CircuitsoftCircuitsoft Posts: 1,166
edited 2013-03-27 21:16 in General Discussion
I would like to build an induction cooktop for myself. The one challenge, as far as locating part is the Litz Wire for the heating surface. I can only find companies that sell it by the Km. Anyone know where I can find smaller amounts?
    edited 2012-11-15 16:08
    ...are you SURE you want Litz wire??? For an induction heater? Errrr..............
  • Mark_TMark_T Posts: 1,981
    edited 2012-11-15 16:29
    Lowering power loss in a high frequency coil - sounds like perfect application:
    http://en.wikipedia.org/wiki/File:Induktionskochfeld_Spule.jpg
    edited 2012-11-16 05:06
    Don't know if this is any use, but why not just harvest the nichrome wire out of a toaster heating element? It not Litz, but its free
    edited 2012-11-16 06:58
    There are lots of Calrod (r) heating elements that are ready made for a stove top, but I suppose you are trying induction heating rather than surface contact.
    edited 2012-11-16 07:50
    Got to reading wiki for litz wire, now I'm starting to understand whats going on.
    What kind of frequency are you looking at? voltage and current?
    This looks really interesting.
    edited 2012-11-16 08:21
    you can get some out of HF tanasformenrs used in some PC power supplys
    interesting use of Litz . I had a senior over last night advising him on his final project . Wireless I pod chager
    http://www.element14.com/community/events/3466 was the base Idea He is going off from . but both a iduct heater and the charger has a ton in common .
    some CRT necks are also known to use litz .
    Peter
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2013-03-27 19:28
    Frequency is 20~50KHz, power is <2KW, hoping to keep dissipation of output coil under 20 Watts. However, frequency may go up far beyond the typical case, since I am hoping to be able to heat copper and aluminum as well as iron/steel, and will need the individual strand size of the litz wire to be significantly smaller than the skin depth at any frequency I can actually drive.
  • RickBRickB Posts: 395
    edited 2013-03-27 20:03
    Induction heating at that power level typically uses water cooled copper tubing.
    http://inductionheatertutorial.com/
    edited 2013-03-27 20:58
    The (cheap) 1.8KW stove I took apart just had (cheap) litz wire and some ferric powder cores behind it. I opened it up because it was making a funny noise. After re-flowing everything on the PCB, it quit making the funny noise and continues to work quite well to this day.
    Recent interest in metal detection has shown me another demand for Litz wire... the coils for the metal detector.
    It has been over 50 years since I played with an Litz wire, but as I clearly remember ... it is not easy to solder. Connections might best be made by mechanical means. Removing the insulating enamel is tricky.. maybe use a torch to burn it off or strong solvents.
    I suppose you could go the other direction and salvage Litz wire from an old metal detector. You might also salvage it from a CRT deflection yoke or a flourescent ballast.
    http://www.elektrisola.com/litz-wire.html
