Frequency Counters, Opinions? — Parallax Forums
Martin HodgeMartin Hodge Posts: 1,246
edited 2012-11-16 23:23 in General Discussion
I've been looking for a good frequency counter and would like to solicit the opinions of those who have experience with these devices.
First, are the built-in "frequency counters" in today's modern oscilloscopes as good as a stand alone unit for low frequency measurement?
Second, what is you're opinion on something like this: http://www.ebay.com/itm/170874206465
Most of what I'll be measuring is < 100MHz clock signals all the way down to 1 PPS signals for time keeping.
  • Mark_TMark_T Posts: 1,981
    edited 2012-11-14 16:01
    That ebay one looks reasonable but alas only has +/-20ppm accuracy which is pretty poor for a dedicated frequency counter. I'd suggest only go for ones that specify the accuracy, tempco and age-drift of its frequency standard.
    If you only ever want to measure frequency of logic signals I wouldn't necessarily bother with a special unit, a Prop can be pressed into service (actually having said that I'm surprised there is only one match for "frequency counter" in the Prop Obex...)
    edited 2012-11-14 16:36
    Have to agree with what Mark_T posted. The accuracy of the frequency measurement is only as good as the timebase accuracy. Use a precision oscillator for the Propeller and it will do the job for any frequency up to the max the counters can handle, and just about any time period you want.
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-11-14 17:31
    Ditto!!
    Simple counters are easy and cheap to make, it's not rocket science.
    Quality is all in the reference.
    Most counters allow the use of external references, usually 10MHz.
    Really good ones use rubidium references
    BTW, make sure the counter can do the inverse, or measure period.
    And a big step up is in the front end.
    The high end HP counters can also measure the analog phase of the last pulse in the string of pulses they can add at least 2 more digits.
    Why is this important?
    It, lets say, they added those 2 extra analog digits the count update can happen about 100 times faster than a similar resolution on a regulator counter.
    Duane J
  • jmgjmg Posts: 15,193
    edited 2012-11-15 01:43
    For that you need a Reciprocal Counter, and anything half decent these days, should use reciprocal Counting.
    Check how many digits they do, and the timebase precision, and there is also this, for low frequencies.
    http://www.daqarta.com/dw_freq.htm
    I gave the Developer a nudge a while back, and he extended the precision and sampling choices, to allow better than Crystal values. - and I got him to add an update 'Winky' , as I could get mine to sit unchanging over many samples, and that makes you unsure if it is really working :)
    Before, the display LSB was a limiting factor.
    Some slope helps, as it uses linear interpolate to resolve the zero crossing.
    If you have a 'nothing fancy' counter, you can push up the precision with a TCXO, or higher standard.
    Or, you could wait for the Prop II - I think Chip has added some smarter features to the Counters, to better support Reciprocal Counting.
  • BeanBean Posts: 8,129
    edited 2012-11-15 04:37
    Here is a reciprocal frequency counter I wrote in PropBasic.
    It reads the frequency on P0 and outputs to the PC @ 115200 baud.
    It sends the frequency reading with milliHz 0.001Hz resolution.
    ' Frequency counter (0.5 Hz to 40 MHz)
    ' Counts frequency on P0, sends ASCII to PC at 115200 Baud
    ' 1.0 Second gate time (gate time will be longer if frequency is < 2 Hz)
    DEVICE   P8X32A, XTAL1, PLL16X
    XIN      5_000_000
    BAUD     CON "T115200"   ' Baud rate for PC communications
    Signal   PIN 0 INPUT     ' Input pin for signal
    TX       PIN 30 HIGH     ' Output pin for PC communications
    cntStart VAR LONG        ' "cnt" value at start of measurement
    cntTime  VAR LONG        ' elapsed "cnt" clocks
    sigCnt   VAR LONG        ' count of how many input pulses have been received
    temp     VAR LONG        ' loop counter
    digit    VAR LONG        ' current digit
    digitSum VAR LONG        ' Used for leading zero removal
    ascii    HUB STRING (20) ' Holds ascii representation of frequency
    PROGRAM Start            ' Start program at label "Start:"
    Start:
      COUNTERA 80, 0, 0, 1, 0 ' Count positive edges on pin 0
      DO
        ' Wait for a signal pulse to syncronize to the system counter
        WAITPNE Signal, Signal
        WAITPEQ Signal, Signal
        phsa = 0
        cntStart = cnt - 4
        ' Count input pulses until 1.0 seconds have elapsed
        DO
          sigCnt = phsa
          cntTime = cnt - cntStart
        LOOP UNTIL cntTime > 80_000_000 ' 1.0 Second gate time
        cntTime = cntTime - 4 ' To account for "sigCnt = phsa" instruction
        ' Calculate  frequency if >= 0.5 Hz
        IF cntTime <= 160_000_000 THEN
          ' Since cntTime is in 80MHz units, the frequency is sigCnt / (cntTime / 80_000_000) = Hertz
          ' Rearranged this can be written as (sigCnt * 80_000_000) / cntTime = Hertz
          ' We want the result in milliHertz (1/1000 of a hertz) so we need to use:
          ' (sigCnt * 80_000_000_000) / cntTime = milliHertz
          ' Okay, now we have a problem, 80_000_000_000 cannot even be represented in 32 bits. Hmmm
          ' What if we calculate the answer one digit at a time...
          ' The leftmost digit is 10 MegaHertz and that digit can be calculated as:
          ' (sigCnt * 8) / cntTime = x0 MegaHertz. This we can do easily.
          ' Now the "trick" is how do we get the next digit ?
          ' We take the remainder from the division, multiply it by 10 and divide again.
          '  by repeating this process of taking the remainder and multipling by 10 we
          '  can get as many digits as we need until we run out of precision.
          digitSum = 0                 ' Sum of all digits so far. Used to create replace leading zeros with spaces
          ascii = ""
          sigCnt = sigCnt * 8          ' Scale signal count to get MegaHertz digit
          FOR temp = 0 TO 13           ' 7 digits + decimal point + 3 digits = 11 digits
            digit = sigCnt / cntTime   ' Calculate this digit of result
            sigCnt = __remainder       ' Keep remainder for next digit
            ' Scale signal count for next digit
            __temp1 = sigCnt * 2        ' sigCnt = sigCnt * 10 using powers of two
            sigCnt = sigCnt * 8
            sigCnt = sigCnt + __temp1
            INC digitSum, digit        ' Add this digit's value to sum
            digit = digit + "0"        ' Convert digit to an ascii digit
            ' If this is a leading zero, make it a space
            IF temp < 9 AND            ' Only use leading spaces for digits higher than the units digit
             digitSum = 0 THEN         ' If the sum is zero, then we have only had "0" digits so far
              digit = " "              '  so use a space instead of a "0" for this digit.
            ENDIF
            WRBYTE ascii(temp), digit  ' Put digit into the result string
            ' Insert a comma if needed
            IF temp = 1 OR
             temp = 5 THEN
              INC temp
              IF digitSum = 0 THEN
                WRBYTE ascii(temp), " "
              ELSE
                WRBYTE ascii(temp), ","
              ENDIF
            ENDIF
            ' Insert decimal point at proper place
            IF temp = 9 THEN           ' If we just processed the units digit,
              INC temp                 '  move pointer to the next character in the result string
              WRBYTE ascii(temp), "."  '  and make it a decimal point
            ENDIF
          NEXT                         ' Process all digits
          WRBYTE ascii(14), " ", "H", "z", 13, 0
        ELSE
          ascii = "Too low (< 0.5Hz)"
          ascii = ascii + 13
        ENDIF
        SEROUT TX, BAUD, ascii       ' Send frequency to terminal
      LOOP                           ' Repeat forever
    END
    Bean
    edited 2012-11-15 17:42
    Bean wrote: »
    Nice, I would tweak the comments just a little, to better match what actually happens in the code
        ; Reciprocal counter captures the time needed for a whole number of Signal Cycles
        ' Count input pulses until at least 1.0 seconds have elapsed
        DO
          sigCnt = phsa
        LOOP UNTIL cntTime > 80_000_000 '  Exit after > ~1.0 Second gate time, on next Signal edge, so time is WHOLE cycles
    I think this code also has a 'precision corner' - at low speeds the actions will phase-lock to the edges, and time values will be edge aligned, but at higher values the time given will not be so edge locked, as the SW pacing loop takes more than a half-period.
    I think the error added is not large, and it will be added on a large edge-count, which can better tolerate small shifts.
    edited 2012-11-15 18:03
    So it looks like I need to start out with one of the second hand rubidium time standards on eBay and whatever I decide, standalone, prop based or embedded into an oscilloscope will be good to go.
    edited 2012-11-15 18:38
    Yes, once you have your 'gold-standard' you then know where you are.
    Another point on the price/precision curve I quite like, is this one
    http://www.digikey.com/product-detail/en/ASVTX-09-20.000MHZ-T/535-9702-1-ND/1578302
    As a VCTCXO you can trim this to better then the default ±0.5ppm, if you have a GPS 1pps for example.
    edited 2012-11-16 22:29
    I'm thinking maybe start with : http://www.ebay.com/itm/280905645392 And clock one of my DNA boards with it's 10MHz output at PLL8X and use the touchscreen I have from Rayman. Or would it be better to use a standard crystal for the Propeller and run the 10MHz as a separate input?
    Probably simpler to use it to clock the board.
