RaspPi deal?
NWCCTV
I am not sure but does anyone think this is a good deal? http://www.mcmelectronics.com/product/83-14346&green=2ddffc00-5ee0-906bf-182a-f61aeccb1923&utm_campaign=MyBuys&utm_medium=Recommendation&utm_source=prod&utm_term=83-14346
They also have just the RaspPi for $40.00.
I ordered a Cubieboard with a 'case' (two sheets of laser cut Lexan to sandwich it between) and with fast shipping for $79USD. But you can get one without the 'case and slow shipping for $59USD.
Sure it is bigger than the Raspberry PI, but twice the RAM, a SATA interface, IR sensor built in for remote control, and a lot more GPIO.
Of course, if you are in love with credit card sized computers and the lowest possible price - the Raspberry Pi cannot be beat. You will have to buy a USB hub with independent power for it two work with most keyboards and USB addons.
Oh, and it is all a charity...........
I'd go with teh Pi, the wall wart and maybe the pi plate or the prototyping kit....and an USB wifi adapter. I think I like the Adafruit clear aacrylic case better, too. That will be my choice.
How come the long-promised $25 pi is $35 everywhere? These days, people get crucified for being 10% over cost; this one is 40% over!
http://www.gizmag.com/raspberry-pi-personal-computer-launch/20944/
the $35 rpi has ethernet, an extra part. the $25 is the non-ethernet, appearantly everybody perfers the next step up. We won't be using the $25 unit unit we work out a very cheap ($2 or less) wireless option
I do see your point. Remember that when they started out there was no such thing as even a $35 computer like that. Since then all the world and his dog has jumped on the idea. That's good old capitalism for you. So they did good in bringing prices down. And you know what? They don't mind. They consider it a job well done.
The idea was to put out a version with Ethernet for developer types and tech-savvy folk to jump-start the process of development environments, hardware and support for app development (protocol libs, etc...). The $25 version has not yet seen the light of day other than the prototypes. When/if the $25 version arrives as a product, non-developer types, student users and those just needing an inexpensive device will have a board at a low price.
The $35 version is NOT the promised board...
dgately
Other than speed and memory size, you can do "just about" anything that can be done on a Linux-based CPU, with the added benefit of General Purpose I/O, I2C, SPI, etc support. Many are being used to render websites, act as servers, digital video devices and much more. Right now, I have one displaying its internal CPU temperature to an 4X40 LCD. And, can run propgcc on it to program my Prop boards.
dgately
Does the IP camera in question require a router for normal operation with networked PCs? I assume that the RaspberryPi would require the same configuration, with the RaspberryPi and the IP camera connected to the same network via a router/switch (access point). Unless, the RaspberryPi can work as a router or access point. That would be a great question for the RaspberryPi or Debian Linux forums...
http://www.raspberrypi.org/phpBB3/
http://forums.debian.net
dgately
google is your friend here, there are many.
out of 400,000 unit, at least a couple apps should interesting
I have an MK802 II here ready to try. Bought mine a couple of months ago on eBay for $51 but you can snatch one cheaper. Better than a Pi IMHO because 1GHz (can clock to 1.5GHz I think) has 1GB DDR2 ram and WiFi in a dongle case requiring 5V. Runs *nix and Android ICS. Has HDMI. My preference is WiFi instead of ethernet, so this is a steal.
400,000 people say they are worth it. You can either trust the data or read the data sheets and do the analysis. You should do both, but for $35 its probably reasonable to just buy it already.
Doug
Which IP camera exactly? Canon? Axis? BrickCom? Edimax?
It'll depend a bit on how they send the images across (how compressed they are) as well as how the web viewer is constructed. You could end up with layers of browser plugins which might slow it all down.
But I have seen people easily watching full screen movies, and running remote apps and it seems pretty snappy. I think it will come down to how they bind the software together...
Any and all, pretty much, depending on what the client purchases. Most IP cameras today are running H.264 compression. Once the IP address is set the device I need just needs to bring it up on a web page.
http://www.raspberrypi.org/archives/2555
Power dongles can be had for 5$ and the tenda wireless usb dongle for 10$. I mostly access the devices via ssh.
