New Boeing Spy Plane — Parallax Forums
  • LawsonLawson Posts: 870
    edited 2012-11-12 09:49
    I find it really odd that a hydrogen fueled spy plane designed for 4-day flights isn't using a fuel cell for at least one engine. Specifically, the high temperature solid oxide fuel cells can hit over 60% efficiency. That should double the endurance of the plane. You'd still want to keep the IC engine for take-off, climb power, and backup. (though I'd add a folding propeller to the IC engine side) Maybe that's an upgrade planned for a "B" version of the Phantom Eye?
    Lawson
    edited 2012-11-12 09:59
    And while you're at it, fill that blimp-shaped internal cavity with hydrogen for extra lift. At least blaugas!
    http://en.wikipedia.org/wiki/Blau_gas
