Beaglebone A6
xanadu
Lightly used for node training, flashed to factory image, works perfect, no cables included. $50+shipping.
xanadu
That's the XM or Pi you want then.
You mean like streaming an MPEG? I didn't try it. It can serve up HTML with the embed code to a video in the onboard storage so long as the client browser could decode the stream. In fact I think the demo mode plays some Flash videos, you should ask on their forum with all the specifics. I just got this for playing with node.js and GPIO.
You can embed the IP cam's viewer into the HTML page on this thing no problem. From there it is the work of the browser and IP camera's feed. The easiest way to do that is open the page to view your IP cam, view the source of the page and copy and paste it into your HTML on the BeagleBone. You can get a web server up and running on the BeagleBone in seconds, and only a few lines of code. If the viewer is watching an IP camera you put on the page that the BeagleBone is serving, the BeagleBone doesn't render anything, it just tells the browser where to find it.
If you're asking if the BeagleBone itself has a video output port, it does not.
What do you got? I'm really trying to downsize, I still have a ton of parts and three more robots to sell. The end result is one UAV and one medium size robot, if you have anything related to that let me know.
Spin Prop NIC New 1
BS2px Module/pe/p40 1 of each
BS Sumo control board 2
BOE Board- Serial type 1
2x16 LCD 1
Flexiforce Sensor 2
XBee antenna Style 2
Stepper motors. All sorts and sizes. I have a bunch of other stuff too but need to inventory it all. Not sure if you can use anything here but if you can I am up for trading. If you can not use any of this I certainly ubderstand and will get other items posted as soon as I get it all sorted out.
