TED Talk: User-Friendly Robots
http://www.youtube.com/watch?v=blLWpdGtYRQ&feature=watch-vrec
Interesting thoughts on empathy and emotion, but for the time being I'll stick with sharp jagged claws and flamethrowers.
I'm also skeptical about her demo with the bipedal robot at the end. I suspect that it was scripted and not actually translating.
I found the robot she was using. It's for sale, but only to researchers:
http://www.robotshop.com/aldebaran-robotics-nao-h25-humanoid-robot-academic-5.html
The CPU is a 1.6 gHz Atom, so at best it could run the Dragon speech software, but I doubt it could translate to Japanese.
It says there is a second CPU located in the Torso and can interpret 8 languages. For the money I could hire an interpreter and a maid and get more done!!!!
Only $15,000 each in a five-pack.
Personally, I'm sick of seeing Nao on the cover of ROBOT magazine every other month. Gimme something I can use. Or afford.
Hmm, I read that it could text to speech in eight languages, which isn't translation. Even with awesome voice recognition you need to translate text from one language to another. That's a hard problem. Since it has wifi built in, it might be calling for help from another computer.
That "universal image translator" could be quite handy, although no substitute for learning a bit of the language yourself. I've travelled a lot, and just knowing "please", "thank you", and "can you help me" can work miracles abroad. Most people are eager to help wayward Americans who show any bit of politeness and courtesy. Yes, even in Paris!
Empaths are still considered paranormal, and the stuff of Star Trek. Humans and some animals can have empathy, and it can be simulated in artificial intelligence. It's not true empathy because the machine does not have the same experience as the object it's being empathetic toward, but it can appear to onlookers that it is understanding your emotional state. It might learn to observe those states and predict things such as mild annoyance turning into red-faced anger, but as it lacks the primitive -- yet highly complex -- brain functions that create these emotions, it can only simulate a reaction.
On the other hand, machines at present are simply incapable of sympathy, which involves caring and numerous other highly evolved emotional states.
-- Gordon
In current usage, particularly among New Age adherents, empathic is like telepathic; both are studies in the paranormal. Empathetic is the correct term to use to avoid confusing AI with some other sixth sense not clearly defined.
-- Gordon
