Self-Portrait of Curiosity by Rover's Arm Camera
On Sol 84 (Oct. 31, 2012), the Curiosity rover used the Mars Hand Lens Imager (MAHLI) to capture the set of thumbnail images stitched together to create this full-color self-portrait.
This self-portrait documents the state of the rover and allows mission engineers to track changes over time, such as dust accumulation and wheel wear. Due to its location on the end of the robotic arm, only MAHLI is able to image some parts of the rover, including port-side wheels.
The mosaic shows the rover at "Rocknest," the spot in Gale Crater where the mission's first scoop sampling took place. Scoop scars can be seen in the regolith in front of the rover. A portion of Mount Sharp appears on the right side. Mountains in the background to the left are the northern wall of Gale Crater.
When the rover returns the full-resolution MAHLI frames of the scene, the team plans to generate a more detailed portrait of Curiosity in its Martian neighborhood.
this is interesting.
Who did the photo and how?
I do see no attachment connecting the camera to the rover. How does this work?
Even when stitching thumpnails you need some attachment, don't you?
just curious
http://www.nasa.gov/images/content/703574main_MSL%20self-portrait%20pia16239%2020121101_full.jpg
With the overlapping images you can remove the bits that show the support. This is done frequently in spherical panoramas such as you might see on a real estate website.
Mystery solved, we can see the reflection of the man that took the photo in the mirror ontop of the tower, eh
Absolutely amazing picture!
Aha Now we know the truth! click on the open map button to the left and it gives you a street level option, so martians had streets!
I think I see some cattle grazing near the clump of trees to the northeast...
