Monster in a Box
Hey guys! Here's a video showing my project that I was working on (and asking all the n00by questions) LOL
http://youtu.be/2pkMfcFDVvs
I have the Propeller Proto board driving a MP3 player, fog machine remote, stepper motor, and strobe light - and reading a PIR sensor for my Monster in a Box Halloween prop
for the MP3 player I am turning on power to it through a 2n2222 transistor, the fog remote had a battery that I just couldn't get to match right so i am just "pushing" it's buttons with two reed relays (the fog machine works by pressing an on button and then a separate off button) - the strobe light is on when it's plugged in - no other control - so I spliced it's wire and am controlling it's power through the relay board, powered by the 5V regulator from the Prop Proto
there's a few things I have to fix for next year - you can't hear the MP3 sound when the box is bouncing the lid - so I need a better set of speakers or amplifier and I would like the bouncing of the lid to be more random - which I can control by changing up my steps to the stepper - should be easy enough but I BARELY got this done in time to scare the kiddies last night
thanks for everybody's help on the forum - without you guys answering my questions I'd have never finished this!
Jamie
Jamie
Add rubber bands to the roller following the cam to reduce the lid noise? Replace chains with (bloodstained, frayed) ropes for same reason?
He's got great analog designs here (starting at about 4:40), but it sounds like he's working on a digital approach, too, based on the Propeller.
Although I cannot take credit for the idea, nor some of the implementation
If you can add an air supply a randomly fired pneumatic will give you much more lively performance from the lid. You can point one down, too, to cause the box to jump up and down.
Congrats on a successful prop -- and now that you have the platform, you have ~364 days to make updates!
Halloween props is a healthy addiction where you just want things to be better and better every year!
All kinds of cool ideas come to mind! A game I made recently included a Propeller and four servos. It was a surprising hit (no pun intended). Pneumatics would take it to a whole new level. Almost steam punk.
Also, high pressure air escaping from a section of 1/4 inch surgical rubber tube makes for unexpected movement is a darkened passage way.
My son has used many of these tricks in his Halloween Hunted Houses.
It is ALL fun and games in October.
Shades of creep show, NICE WORK!!!
Nah, keep the change er I mean chains. Maybe have the prop vary the motor speed for a bit more random opening. Oh, maybe add a couple of pneumatic lifters to the box to make it jump up a bit as well. Maybe mirrors or reflectors around the top lid to illuminate the ground when the lid is up and the strobe fires. Could not see much effect from the internal lights in the video.
Oops, late to the party, looks like JM already suggested lifts.......
yes I think for next year I will just get louder speakers, or mount the speakers outside the box where you can't see them - simple - easy
I had worked on electric solenoids to try and bounce the box up and down (because I didn't want to venture into pneumatics yet) but they were not nearly powerful enough to make the box move violently enough - they lifted it, but it was lame LOL - I will probably start playing with pneumatics before next year so we'll see on that
I think part of the problem with the strobe was that I made the lid recessed in an attempt to make sure the stuff inside was hidden from view but I think I choked off some of the light too
