Faster BoeBot — Parallax Forums
Faster BoeBot
Matt GillilandMatt Gilliland Posts: 1,406
edited 2012-10-29 08:04 in Robotics
Just testing an idea...
Same power, same servos, same code...
[video=youtube_share;9PAzqughSuM]
-MattG
    edited 2012-10-25 10:45
    Same power, same servos, same code... external gearing. Nice!
    edited 2012-10-25 11:28
    Let's see, use servo to gear down a motor and then add external gears to gear it up? Do I have that right?
    edited 2012-10-25 11:51
    Matt, neat.
    Duane Degn wrote: »
    Efficiency wise it's not the best, but I imagine that you could create a new internal gear set with the same effective gear ratio.
    Let's see, look at a really quick, proof of concept prototype and poke fun at it? Do I have that right? :lol:
    :tongue:
    -MattG
    edited 2012-10-25 12:15
    :tongue:
    -MattG
    Dead right!
    I'm trying to figure out how to attach the BOE-Bot wheels to one of the servos' internal gears to make this concept more efficient.
    edited 2012-10-25 12:37
    Or ... you could just use bigger wheels. :)
    edited 2012-10-25 12:40
    You know what's really cool - I've got all you amazing guru's to do the "heavy lifting" for me...you come up with great ideas, I then delete your post, and then I take the idea as my own. :tongue:
    I mean, think about it. Is Phil really that bright? There just may be some under-world connection between Phil and Browser - and Browser shows no mercy - he has super-user privileges here -
    Ok, now I scared myself...he's a cat, and he's lurking...I can feel it. :lol:
    -MattG
    edited 2012-10-25 12:51
    Close ups...
    -MattG
  • W9GFOW9GFO Posts: 4,010
    edited 2012-10-25 13:11
    Yeah, I like that idea. Wanna race?
    1024 x 765 - 124K
    edited 2012-10-25 13:21
    Matt,
    I get how the servo splines are laser-cut in the spur gear, but how did you make the shaft that connects to the wheel?
    Rich,
    Now those are big wheels! What did you use for tires?
    edited 2012-10-25 13:25
    I use the same "tires" that are used on the standard wheels, I'm surprised that they stay on so well. I do plan to make a groove and use an o-ring in the future.
    edited 2012-10-25 13:42
    I'm more surprised that they stretch that far!
    edited 2012-10-27 08:41
    Looks like magic to me.
    The vacuum cleaner belt replacement department at Walmart or other discount store will have you swimming in larger circumference rubber orings and belts. They're actually better than the standard buna rubber orings you might buy as they have an additive that resists breakdown from oils (skin oil, oil in carpet, whatever). How many of youse guys still have the original orings from the original Parallax BOEBot wheels? Mine disintegrated years ago -- the oring tires, not the wheels.
    Anywho, from a frictional efficiency standpoint, the larger diameter wheel is more efficient than spur gears. However, the spur gears allow the use of existing Parallax plastic injected wheels.
    -- Gordon
    edited 2012-10-27 08:50
    Matt,
    Looks like a 4-40 machine screw. There's a lock nut against the inner gear (the white one, which seems to be used as a spacer); the end of the screw goes through a hole in the BOE chassis to support it on that side. The wheels are held in position with a laser cut pillow block, that in turn is mounted to some undercarriage. At least that's what the 2.5 second shot of it in the video seems to suggest.
    -- Gordon
    edited 2012-10-27 19:55
    Gordon,
    You got all of that from 2 1/2 seconds? Impressive! :)
    edited 2012-10-28 11:07
    :tongue:
    -MattG
    I'm sorry I was on vacation and missed the opportunity to poke fun at it. Was it a contest?
    edited 2012-10-29 07:58
    It's tough to show, but this was truly a "guerilla-get-it done-quickly prototype".
    What I did was cannibalize two other servos and took out the final gear (that had a bearing cavity on one side). So I used that as a "detached" shaft extension - essentially the device requires the drive shaft to be aligned very closely to this final gear's shaft receiving hole - it wobbles a bit (because of slight shaft mis-allignments, but it worked well enough to prove/disprove torque question-ability.
    un-reliable, simplistic, and cheap. my middle names.
    -MattG
    PS When Andy's finished with testing it, I'll shoot an exploded view pic - just as long as none of you laugh...
    edited 2012-10-29 08:03
    Perfect timing :lol:
    -MattG
    Inexpensive maybe, but never cheap!
    -- Gordon
