Robot Pictures
Been working on getting all the parts to fit in the battery box but no matter how I arranged them they were not going to fit.
List of item that needed a home.
(2) 17 Ah sealed batteries
(1) Eddie Control board
(1) Mini ITX motherboard
(1) CPU Power supply
( 1) 500GB Hd
A bunch of wires and connectors
I ended up making a clear panel on the outside of the battery box to mount the Eddie control board and the switches
for Master Power , CPU power and Motors enable.
After powering everything up on the bench I started to pack it into the Battery Box. Most of the wires are way to long and I will trim them and make a nice wiring harness.
I still have a lot of work to do so keep watching for updates.
And last my warning sticker.
( 1) 500GB Hd
Last major hardware issue is to interface the 10bit encoders and the Ping and IR sensors.
Moved the Kinect sensor to the top of the monitor but I don't think its going to be a good spot to use it for navigation.
Cover still don't fit. looking for some 90degree usb adapters and a monitor 90 degree plug.
Started on the Ping mounts for the front and back.
http://www.youtube.com/watch?v=3ZYSuiPHUG8&feature=plcp
Having trouble fitting the cover on the robot because the Monitor and the USB cables are
facing upwards and are to tall for the cover to fit properly.
Went searching for right angle plug's couldn't find any so I just made my own.
Ordered the 3 IR sensors with cables from Parallax today. I asked for Parallax stickers too hope they don't forget to put them in the box!
Also I knew my Motherboard had 12 USB ports 6 on the back panel and 6 on the mother board in the form of 3x 10 pin headers
with 1 header supplying 2 ports. Found some 6 inch USB cables with pin header plugs on them 2.50 each.
And mount the cover.
Hey jdolecki - nice work! If stickers don't show, let me know :thumb:
-MattG
After this weekend I will change the paint scheme and figure out to incorporate the Parallax stickers / logo.
Thanks.
http://www.youtube.com/watch?v=73GCooj41Uc&feature=plcp
dolecki had a little bot, little bot, little bot...
...it followed him to school one day, that was against the rules
It made the children laugh and play to see a 'Bot at school!
http://pumpingstationone.org/
NERP provides a place for learning, discussing, and experimenting with the Raspberry Pi. Although our main focus is on using the Pi, other relevant topics include embedded devices, Open Source Hardware and Software, interfacing to the real world, development tools, circuits, and so on. Topics can be of general interest or advanced and highly focused. The NERP wiki lists many resources for learning and using the Pi.
http://www.meetup.com/NERP-Not-Exclusively-Raspberry-Pi/
