Powring a window air conditioner with Password pad
How are you doing all... I have a small issue I wanted to take some of you input in... As the title of this thread suggests ... I am thinking of building a pass code pad for my window air conditioner...so that you would need to insert a pass code in order to energize the AC on and the same if you want to de-energize it.
At the top of my head, I am thinking of using high rated driver (that handles about 1500W), a microcontroller and a numbers-based pad... I am not sure if this actually feasible and would work or not...
if any of you has a comment or suggestions please help me out...
Here's a relay that should be able to handle the current to the AC. You'll need a transistor to drive the relay. SparkFun sells a kit that includes the parts needed for controlling a relay from a microcontroller.
If you're using a 3.3V microcontroller, you'll need to make a couple of small changes to the relay circuit (in the above mentioned kit) intended to be used with 5V microcontrollers.
I like these keypads from MPJA (mainly since they're cheap).
Tonyp12, I like your idea....straight to the point and much easier solution...lool
I notice from all your replies that I really need a relay...
Duane.... I am not sure what type of Microcontroller I am ganna use...I am pretty comfortable with PICs since I worked with in several projects...However, I might try something different this time...maybe one of Arduino modules this time... I will keep in mine the 5 V issue ...I really like your suggestions for the parts I think that is exactly what I need...I have one concern thu, I have not experience with AC current and power before so I am not sure what kinda risk I might face specially in terms of safety. In This project.. I am planning for controlling a 24 BTU ..so that is a lot of power...will the module you suggested be safe assuming that the Air Conditioner will be on for long periods of times...??
Schwabe,, LOOL not playing devil advocate...As a matter of fact I am helping a friend ..His problem is that people keep shutting his Ari conditioner off while he is a sleep to wake him up..!! and it is really pissing him off..so i suggested this idea ... plus keep in mind that I have a lot of free time..basically bored !! plus I want to doe some projects interfacing with AC power appliances to do cooler stuff later on..:)
