Library of basic circuits with the propeller?
Is there anywhere a basic library of circuits? What I would like to see is a listing of a bunch of basic circuits you'd make with the propeller and the code needed to make them work
like
1. Propeller driving an LED (simple yes I know but you have to start somewhere)
2. Propeller driving a transistor (then maybe expand on the super basic to then drive something with the transistor?)
3. Propeller driving a Mosfet
4. Propeller driving a Relay
5. PIR Sesor circuit
6. Ping circuit
etc... Seems that anytime I go searching in the forums #1 I get a bunch of schematics but they are incorrect or are argued over - so there's a log of garbage to weed through - same with the object exchange - every time I've searched the results are either not basic enough or just can't find what I need or just wrong - like when I post up my "hey does this circuit look right for so and so" well that circuit comes up when I search and it's just plain wrong - so I have to read entire pages of threads to try and get to an answer - that I think should be as a library somewhere
If this doesn't already exist outside of these forums then I think i will create it - even if it's just for me
Jamie
like
6. Ping circuit
Jamie
Everybody is doing something, but rather piecemeal via websites. For instance, there are various transistor solutions from 2n3906, to 2n2222, to TIP120. All work, but each has a best fit for a project. It would not hurt to explain a little about how much power you really need and at what voltage. (So many users think that a transistor fed by +5V will actually deliver +5 volts..... not enough education in all those quickie HOWTOs.)
Why a book? While I am sure many of us will just go to http://learn.parallax.com/ for an answer, "THE Shopper" that is new to micro-controllers is more likely to buy a Propeller board if there is a good informative reference text available at the same time. Books knock down the rationale that something is going to be too complicated. Websites can't really reach the retail shopper at the moment they are really trying to decide yes or no.
And of course there are those of us that like to read books - just because there are no batteries to recharge or replace. (or can't get the laptop away from other family members.)
I have one good book like this, but it is all in Chinese and for a competing product that shall not be named. I am pretty sure that the fact that it is comprehensive and sold in regular bookstores without the product is creating demand for their product anyway. Still, it is useful to me as I can read the schematics, and it is kind of interesting to see how they program C in Chinese.
Someone out there can be the next Forest Mims.
Driving things like an NPN transistor is no different with a 3.3 volt propeller versus the BS2 or Arduino. The 3.3 volts is high enough to activate most transistors. For other circuits (e.g. driving an LED) the thing to consider is adjusting the current limit resistor using Ohm's law V = IR. Suppose I'm driving an LED on the BS2 using a 330 ohm resistor.
5 = I * 330
I = 0.015 or 15 mA.
So 3.3 = 0.015 * R, yields a new resistance of 217 ohms. So where I see 330 ohms I replace them with 220 ohms and move on.
Duane J
http://propeller.wikispaces.com/
You can also integrate an existing page or create a new one.
I usually refer to it and there is a lot of stuff.
Massimo
Once again, OMG. I never get anything right.
"Ah, Don Lancaster wrote the "CookBook"s." ... for the record, I personally sent Don Lancaster a Propeller Demo board a few years ago.
The bidirectional solution is a simple MOSfet with a few resistors. While it works great, someone like Siemens has patented it - so some are not willing to discuss it.
5V to Propeller, use a 3.3K resistior ( I previously mentioned a 1K and was told No, No, No!).
Going out of a Propeller is often easier as 3.3 volts often works fine with 5 volt logic.
What is driving me crazy is that nobody seems to be aware of the fact that transistors have at least 0.6-0.7 volts of drop when placed in a circuit. And often this increases to 1.0 or more volts if the transistor is driving at saturation with a high load for it. That means that one cannot power all and everything from 3.3v and 5.0v - at times one need a higher voltage in order to get the right voltage with adequate current. But people tend to want to avoid multiple voltage power supplies and just run everything off of one voltage.
"The bidirectional solution is a simple MOSfet with a few resistors. While it works great, someone like Siemens has patented it - so some are not willing to discuss it. " - I protest the patent on this... it's nothing more than a common gate amplifier, that has been renamed 'bidirectional level shifter'
Compare the two circuits if you wish ... low voltage on one side higher voltage on the other... an amplifier.
Reference Common Gate amplifier:
http://en.wikipedia.org/wiki/Common_gate
Reference Bi-Directional level shifter:
http://ics.nxp.com/support/documents/interface/pdf/an97055.pdf
BTW, would you like to write an intelligent informative book of basic Propeller circuits? I'd actually do it if I was able to, but I can't work with a keyboard intensively for any period of time (nerve injury in the neck).
Students and newcomers just don't get the importance of the math side of things or that Power, not not Volts has to be properly scaled. I suspect everyone is using their voltmeter, but no one dares to use the ampmeter in thier multimeter. After all, that has a fuse they might blow.
"BTW, would you like to write an intelligent informative book of basic Propeller circuits?" - Time and resource are my enemies at the moment or else I would love to, I've been wanting to do something like this for years. It will happen some day, just not now. If I were to put something together it would follow something more along the lines of "101 projects you can build with a Propeller"
Well I think I am going to start collecting some notes and basic circuits into one place - just really for my own benefit, but I will share with everybody - I really want something on the web - searchable... I've come across tons of circuits in books and then when it comes time to need them I can't find them again LOL
Going to put them here http://www.backyardworkshop.com/reference-material.html if anyone cares
Jamie
I think you are driven crazy for no avail ;-)
There are several ways you can use a transistor. What you describe is only true for an emitter follower configuration, which is normally not used to drive loads from an IO pin.
The normal circuit is to connect the load at the Collector, and use the transistor as a switch. In this configuration the saturation voltage between Collector and Emitter is around 0.1 Volt (depnding on the transistor and the base current).
Andy
BTW, discussion of patents can't be restricted since the patent publicly discloses the idea to all.
In reading this patent it appears they are describing the circuit with only Enhancement Mode MOSFETs. Generally, the gate is connected to +3.3V.
However, if Depletion Mode MOSFETs are used the gate can be connected to ground instead of 3.3V. I tried this and it works just fine.
Since the patent doesn't describe this basic method I suspect I2C level shifters using Depletion Mode MOSFETs is free to use.
Duane J
I have extra copies of both of Matt Gilliland's books and will gladly mail you the extras as a gift. Just PM me with your mailing address and I'll give them to you.
Parallax and the members of this forum have been very generous to me so I'd like to pay it forward. These books are oriented to the BS2 but the concepts apply just fine.
Paul
The only thing I don't like about this book is- when I read it, my wife looks at me and sighs, and shrugs her shoulders, and asks (someone unseen) "Why me?" ... then she calls me a dork and goes off to watch Housewives of wherever.
BUT- she watches it in another room where I can't hear it, so I WIN!
Robert
I agree that it would be nice to have a categorized collection of circuits ready for Propeller use.
@Duane C. Johnson
Patents are more open then just discussion. Patents cannot be copyrighted, therefore you can print, reprint, distribute, and sell the written documentation. The patent just offers protection from infringement of someone making or using the patented item without a license.
Check ebay, they sell all kinds of patent copies.
I think the problem is more specific than that - people often quote part numbers that are literally 40 years out of date - modern superbeta transistors have Vsats in the 0.05 to 0.2V range for reasonable current levels, and far superior current gains at high current. If switching upto 2A there's no need for Darlingtons or MOSFETs for instance, a ZTX851 has Vsat of 0.15V at 2A - blows the 2N2222 out of the water (at a price of course). Of course a lot of superbetas are SMT only which makes it tricky. A superbeta replacement for the ULN 2803 would be nice to have
Yes it is an awkward juncture for electronics as a hobby. The 2n2222 is easy for me to purchase over-the-counter in Taiwan and likely around the world, while the ZTX851 might really be a pleasure to use. People in the USA and Europe and maybe Japan can find it easy to buy modern parts - but most of the world is retailing older stocks. Getting free samples can result in having to pay quite a bit in shipping.
Of course, if beginners used super-betas, they might be even more ignorant of what is required for a good circuit as the devices would be even more forgiving of ignoring the details.
Added is the problem that surface mounts require a very different approach to assembly.
When all of these factors are combined, it is really difficult to write educational material that is up-to-date and allows the reader to build from scratch.
So I suppose that the real solution is a series of 'educational shields' that can be adapted to any of a variety of micro-controllers. I already do something like this by building cables as adapters between boards rather than depend on stacking for extending.
Regarding books.
I guess I just miss the halcyon days of the annual ARRL Handbooks.
12au7 amplifier designs
your sliderule and you
rtl logic handbook
experiments with the 2n107
come on down. free shrimpz evry satterday.
-browz
Only 3 more years until expiration! If we all wait about 36 years, just about everything now under patent will be in the public domain. Of course, I will be about 101 years old, but what the heck.
I think I will rely on the 'urban myth' that anyone can copy a patent one time for personal use. Or better yet, I can do this because I am just one tiny fish in a very large ocean. Maybe we should start an NGO to defend patents. that should be in the public domain, but are being claimed by big companies anyway.
I miss my slide rule and always wanted a circular one, but the world has gone to spreadsheets for number crunching.
If you really want to look around for books, why not try your local public library. They used to be pretty good.
Siemens is German.
I saw a straight slide rule a few days ago. Interested? Shall I keep my eyes open for a round one?
Don,t know what libraries are like where you are but here there are quite a few computers and nowhere near as many books on the shelf as there used to be.
Edit: one of my latest finds in a goodwill store was "Introductory Electronic Devices and Circuits" by Robert Paynter. C 1989/91 Older, but the title understates the amount of material presented. Something I have not seen in other books, each section goes into troubleshooting the circuits presented.
I have a couple of the Don Lancaster "cookbook" books. My favorite was the TTL cookbook. Don't remember how many times I read it cover to cover!!
