Lumen Electronic Jewelery
Lumen is a collaboration between my sister and I to make solar powered Jewelery out of electronic circuits. (It's alive!)
Our web-site is http://www.lumenelectronicjewelry.com/ and we're using Kickstarter to help get the first batch out the door.
Right now, we're using comparators and 74 logic to drive the designs, but I'll start using a Propeller for future designs with more complex sequences. (This is an early proof of concept for Prop core Jewelery)
Lawson
Lawson
Bruce
It looks like there are four little solar cells on there, or one big one for the tulip design. That would make them running on less than 2V?
Once upon a time I was fascinated with neon bulbs in relaxation oscillators and made a few art objects with 10 or 12 bulbs that ran for a year or two on a radio B battery. (Try to find one of those these days!) I still have a night light I made back around 1968 that has 10 blinking NE2 bulbs, still going; it plugs into an outlet though.
I'll keep that in mind. So far we're happy with a thick epoxy coating. Bubbles and wicking have been the biggest problems so far. If the epoxy touches the USB connector at all, it wicks up inside and plugs it up!
Yes, the Square/Skull circuit designs run from 0.8 to 1.5 volts using four crystalline silicon solar cells. (more details here) I've found that 74 series CMOS logic IC will "run" and drive a 1uA load if supplied with at least 0.75 volts. The Dragonfly/Butterfly circuit runs at up to 2.5 volts, while the Tulip runs at up to 5 volts. The Tulip's "single" solar cell is actually six amorphous silicon cells in series.
Lawson
Those panels are amorphous silicon film I believe - less efficient (but cheaper) than either polycrystalline or monocrystalline silicon cells. Calculators only take a few mW if that.
Those designs are great. I'll put myself down for an owl or twit-twoo.
cheers
tubular
Excellent designs - how are you storing energy (elect caps? ultracaps?) Good luck and how about a constellation of orion?
Solar calculators use amorphous silicon solar cells. (the next generation Lumen designs will as well) They have a higher terminal voltage than crystalline silicon cells, and only use visible light. This means that the still work normally with high efficiency lights that don't put out much IR light. Solar calculators also use amazingly little power. I suspect most have operating currents of under 5 micro-amps. (so ~12uW going full out.)
@Mark_T: The designs use super capacitors. They store enough energy, and can safely be discharged and stored at zero volts. (which kills most batteries)
Lawson
P.S. Thanks for all the well wishes so far!
