What should our CNC machines make next? — Parallax Forums
Jessica UelmenJessica Uelmen Posts: 490
edited 2012-11-01 06:03 in General Discussion
What do our Motor Mount & Wheel Kit, Caster Wheel Kit and Ping))) Protector Stand all have in common? Why, they're all quality machined parts made right here in at Parallax HQ with our Haas Super Mini Mills!
Now we're looking to expand our machined parts offerings, and want to hear what YOU want to see! We can brainstorm ideas all day, but unless it's something that you want to buy, it's not much good. :lol:
So please, let us know what you would want to see. Here are some guidelines & tips to help get you thinking:
  • CNC milling products made from AL6061/6063. 2.5D machining – chamfers and round edges in X/Y coordinate system is perfectly feasible but 3D surface machining (contouring) is out of the question.
  • Minimal parts to comprise a finished product. Adding screws of various types is entirely fine.
  • Ideal products made on the CNC are those that empower our customers to either achieve greater projects of their own, or make their projects more enjoyable to do.
  • Think about compatibility with our other products.
Looking forward to hearing your thoughts!
Cheers,
Jessica
  • ZootZoot Posts: 2,227
    edited 2012-10-19 11:39
    An aluminum "mast" with mounting plate at bottom and mounting at top for an IMU/gryo/compass/accelerometer. About 18" high.
    edited 2012-10-19 11:41
    Aluminum LCD display bezel/mounts.
  • xanaduxanadu Posts: 3,347
    edited 2012-10-19 15:03
    A robot arm/gripper kit would be cool.
    edited 2012-10-19 15:06
    Erector-set like "struts" that are drilled tapped on the ends, and along the length also have drilled/tapped holes. Some of the holes along the length would be spaced for standard servos, etc. This way customers could bolt things together all sorts of ways, attach servos/sensors/PCBs, etc.
    edited 2012-10-19 16:56
    An aluminum mounting frame for the Serial LCD would be nice
  • dgatelydgately Posts: 1,646
    edited 2012-10-19 19:15
    Zoot wrote: »
    I "third" the LCD frame requests! A bracket that holds the LCD up and at an angle would be useful. I could mount one to my robot or to my controller. Would make the displays much easier to read. And perhaps a bit of a shield for viewing the LCD in sunlight?
    dgately
  • rjo__rjo__ Posts: 2,114
    edited 2012-10-19 20:48
    Open it up to us!!!!
    Let us spec it... u make it. Maybe a good idea... maybe not. Wouldn't hurt to run a trial balloon
    I would like to mount a TSL1401 board to the end of a wheel chair motor... on top of a thin metal can... point at the thingamajig that turns.
    I could draw it... but darned if I know how to explain it:)
    Rich
    edited 2012-10-19 22:52
    More ideas please. Maybe give some thought to small machined parts that make sensors easier to mount and interface, parts for robot drive systems, something related to solar power or quadcopters, or anything we're not thinking of. It's taken years for our CNC machines to be totally caught up, and now we've got a really productive machinist (Kenneth Glass) who can go from drawing to part within a day or two.
  • doggiedocdoggiedoc Posts: 2,257
    edited 2012-10-20 03:45
    How about a V-belt pulley to match up to the motor mount and wheel kit shaft to turn my Parallax parts based 'Robotic Chicken Feeder' I'm designing in my head? :D
    In an assortment of diameters of course.
    edited 2012-10-20 03:49
    doggiedoc wrote: »
    ... my Parallax parts based 'Robotic Chicken Feeder' I'm designing...
    Yes, it will be solar powered too.
  • idbruceidbruce Posts: 6,197
    edited 2012-10-20 04:29
    @Jessica and Ken
    Many years ago Beau made a metal detector for the BASIC Stamp (http://forums.parallax.com/showthread.php?62768-Sensitive-STAMP-based-Metal-Detector-enjoy!!). I think it would be kind of cool for Parallax to create a metal detector development kit based up his initial post, with most of the necessary parts being made from plastic or aluminum. As for the microcontroller, well of course there should be a choice between the Stamp and the Propeller.
    This suggestion must be worth two XBee modules :) Oh, sorry... I thought this was a contest :)
    Bruce
    edited 2012-10-20 07:23
    How about a robot frame kit so we can do a stable robot platform and mount sensors/hardware at short adult height level.
    edited 2012-10-20 07:28
    Track drive?
    Telepresence something?
    omni mechanum stuff?
    Gripper/manipulators?
    Arm and parts?
    Docking charger components?
    -Just chumming the waters here...c'mon all you brilliant minds out there!
    We have a very talented couple of machinists (Kenneth and "Matt H") -
    Put them to the test!
    -MattG
    edited 2012-10-20 08:03
    Could we have some dimensional ideas for what sort of stock the CNC machine can start with?
    If someone has an idea that's 12" x 12" x 3" and the reality is 12" x 8" x 2", then there need to be some re-thinking of the idea to match the reality.
  • ScopeScope Posts: 417
    edited 2012-10-20 09:14
    I'd like to see some toothed pulley's for the stepper motors
    Ah, the thought of sliding on the shiny pulleys, threadlocking the grub screws, using toothed belts . . . could it get any better than that?
    Maybe a rack & pinion option also?
    A sick pan-&-tilt for DSLR's would also be schweet!
    edited 2012-10-20 20:22
    We have a Haas Mini and a Haas Super Mini. I want to say 24" x 20" x 10". I'll verify this on Monday.
    Plus, we have an SR100 which can handle 4' x 8' x probably 6" height.
    -MattG
    edited 2012-10-20 22:38
    -MattG
    Those are the work envelopes, which are really massive. For the stock, any standard 6061 shapes can be put into our vises.
    Three full-size Haas CNC machines, ready to work for you!
    edited 2012-10-20 23:25
    Just to be clear (and I've looked at the specs for the "Super Mini"): 2D cutouts, 2 1/2 D pocketing, drilling, and threading are all on the table, right? But no Z-axis contouring or secondary machining operations, such as right-angle drilling/tapping, etc. Vibratory tumbling and anodizing -- yes? Do you have a press brake for bending thin materials?
    edited 2012-10-21 04:06
    It seems obivious if you have enough available time, make yet another CNC machine.
    edited 2012-10-21 04:39
    Machines making machines! That's how Skynet did it! (After self awareness of course.)
    edited 2012-10-21 06:10
    Maybe a Elev-8 to PropBOE-bot mounting kit? Aerial drops for your robot platform would be pretty cool!
    The CNC parts kit is an interesting idea. Just like a 3d printer, there are probably a core set of CNC'd parts that could be provided to mate up with more common and easily obtainable parts to build a Parallax quality CNC machine.
    edited 2012-10-21 11:22
    Hmmm. Parallax might do well with CNC conversion kits for old lathes and milling machines. After 3-D printers figured out how to exploit the Linux LiveCD format to convert any laptop into a temporary CNC machine, nobody has considered that the same software works well for milling and lathes.
    In other words, I could use a few good standard mounts for powerful stepper motors and related items. Doesn't Harbor Freight sell cheap machne lathes?
    How about some X-Y-Z tables?
  • jdoleckijdolecki Posts: 726
    edited 2012-10-21 11:36
    The brackets for a 3d printer in aluminum.
    Bezels for the lcd screens in alum or plastic.
    Some medium size tracks and sprockets.
    Mecanum Wheels
    A decent gear box or Planetary gear set for humanoid builders.
    Can I just come in on 3rd shift and use the machines?
    edited 2012-10-21 12:05
    Solid gold door knobs for Chip's and Ken's executive bathrooms.
    Parallax brass blazer buttons for Forum VIP sports coats.
    Beanie Propeller blades in anodized rainbow colored aluminium
    Replica Robbie the Robot doorstops for trophies in Forum contests.
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-10-21 12:21
    Lol
  • SRLMSRLM Posts: 5,045
    edited 2012-10-21 19:21
    How about plates and brackets to mount brushless motors?
    A bit more whimsical, but a coil gun would be cool. Perhaps as a kit? I'm imagining the machining part would be for the barrel, and maybe the shot as well.
    How about an antivibration kit for the Elev-8? Something like what Tiger made could be a starting point: http://forums.parallax.com/showthread.php?133372-Ken-Cluso99-W9GFO-JasonD-s-QuadCopter-Build-Log-(updated-info-ELEV-8-availability)/page45
    edited 2012-10-21 19:24
    A Propeller beanie, all in shiny aluminum. I think Parallax needs more swag.
    edited 2012-10-22 01:36
    I think it's called Bling!
    edited 2012-10-22 03:26
    How about Big Big Parallax signs for retailers for the Christmas shopping season?
    edited 2012-10-22 11:15
    Right, no Z-axis contouring. But secondary or tertiary machining operations are always acceptable. They're more a matter of staff time and less of really intense (i.e., long run time) ball-shaped end mill manufacturing. You know your choices for these operations at Parallax: bandsaws, drilling, tapping, additional 2 1/2D machining, etc. We have a vibratory tumbler inside Parallax and we currently go outside for anodizing, so both of these are options.
    We don't have a press brake, automated or CNC at this time. It's one of those sheet metal tools that can be found quite easily in any shop, so it shouldn't be ruled out from a production process either. But be careful if you're thinking about applying CNC operations to sheetmetal [because we really don't want to do much of that if a CNC punch is really the right tool for the job].
    Guess I'll be expecting an e-mail from you where you share your ideas. You can always call me today at Parallax.
