WTS701 Winbond Voice Chip
I need to find the eval kit. WTS-ES701. Eval board that was offer about 5 yrs ago
Hoping some one has one they would like to sell,
OR
Offer to allow me get a copy of the software disk and I will build the hardware
Any help is appreciated, I have a project that is on hold and I'm trying desparertly to find this !
Thanks to all in advance for any help
Chuck
Contact: chuck53@terradock,com
OR
Chuck
http://media.digikey.com/pdf/Data%20Sheets/Winbond%20PDFs/WTS-ES701%20Manual.pdf
Unless you have access to a large number of those chips you may not want to bother since I believe that chip is obsolete now and very hard to find. The original EMIC speech module used this chip but I think it was discontinued since the Speech chip was no longer available. You could ask them if they have the software that went with the eval kit:
http://www.grandideastudio.com/portfolio/emic-text-to-speech-module/
I have the manual, need the software
any help is very appreciated...
someone must have have an eval unit laying around
thanks
CHuck
I noticed that you started another identical thread in the general forum. That sort of goes against the forum guidelines and you should remove the extra post. If you want this thread moved to either the General forum or the Classified section then you can ask a moderator to move it...
Why not reply me about the order on WTS701MF/T?
Don't you get the eval kit?
Please reply me soon.
also found a good quantity of Winbond chips, so I can now program to both Female and Mal English Voice.
thanks
Chuck
