Who knows alot about batteries especially nicads? — Parallax Forums
rwgast_logicdesignrwgast_logicdesign Posts: 1,464
edited 2012-10-20 01:44 in General Discussion
Ok so ive been trying to work out the power source im going to use in my bot... I have all the regulation and all that good stuff for the circuitry, im just left trying to figure out what to do about the motors. The only spec I have on my motors is 3-6v dc, I have tested them and they seem fine at 9vs, but I don't plan on running them over 8, #1 because my motor controller is 8v input minimum but #2 8vs is the highest voltage I can run them out without them being stupid loud.
So right now im looking at using 3 9.6v RC NiCad bateery pack in parallel and maybe a 9.6v nicad drill motor battery also in parallel. Most books you read never explain battery's all that much, they all say the same thing about how they work on a lower chemical level. There are just somethings I dont understand about batterys which im sure are assumed to be common knowlege. The biggest question i have is lets say you have a battery at 9,6 volts with 2 amp hour rating. Does this means the battery can put out 2 amps at 9.6v for an hour? After use batterys voltages starts to drop, so if im trying to supply 8vs to motors with a 9.6v motor i need to know how long my battery will hold over 8vs.
The next thing is when you series batterys the voltage adds up when you put them in parallel the current adds up. Well when you parallel battery with the same voltage but different amp hours, is everything going to run smooth, I mean its not going to be like power regulators where when you parallel them the the whole loads gets drained from the stronger source and overheats is it? I guess what im asking is, is it safe to run different amp hour rated battery's in parallel especially nicads. Also when batterys are paralleled what happens to the voltage is all the batterys have a slightly different charge, will the voltage output equal the lowest charged battery or what?
Lastly is if I throw all these batterys in parallel can I charge them all hooked up in parallel with the same charger ive been using for singles, itll just take longer? What about paralleling multiple charger outputs to provide a higher amperage. Does anyone know of a good through whole IC for nicad battery charging and management becuase all my chargers stink and will overcharge the battery's which causes alot of "memmory" problems, id like to build a custom taylored chargin system for my bot and either use and A to D and micro for battery managment or maybe a fully intergrated battery managment chip, this sounds like something maxim would probably make
  • W9GFOW9GFO Posts: 4,010
    edited 2012-10-17 16:52
    You can parallel packs together but make sure they are all equal in voltage and capacity. Cell reversal is one thing you want to avoid as that will ruin a pack. You can run a single cell down to zero volts without damage. However if you run a pack of cells down too low then almost certainly at least one of them will go below zero because no two cells are exactly the same. This is why there are instructions to stop using a rechargeable tool at the first sign that the battery is running out. It is probable that one of the cells in the pack have less capacity then the rest and it will experience cell reversal. If you ever disassemble a bad pack you might find that only one of the cells is bad - most likely due to cell reversal.
    So, if you parallel the packs make sure not to run them down below about 1.1V.cell. Actually, that applies even if you don't parallel them.
    If you parallel two packs of unequal charge the one with the higher voltage will charge the lower voltage pack.
    A 9.6V 2Ah (19.2Wh) pack probably will not supply 2 Amps for one hour. You may be able to draw 19.2 Wh of energy out of it but only if you do so slowly. The faster you draw power out of a battery, the greater the losses.
    You can charge them paralleled but it is better not to.
    edited 2012-10-17 18:24
    The norm for measuring amp hour capacity is to discharge the battery at a fraction (often 1/10th) of the rated capacity. This reduces internal cell resistance losses and gives a higher amp hour rating than using higher currents. As for operating or charging them in parallel it is a good idea to have a diode in series with each battery when discharging (operating) them, and a small resistor on each one to balance the current when charging.
    edited 2012-10-17 18:33
    I've never seen resistors or diodes used when paralleling battery packs, but I certainly haven't seen everything. It seems like something that is only appropriate for low current applications.
    edited 2012-10-17 20:32
    Ok well I did alot of reading about NiCads a few of the battery packs suck, so I wanted to know about NiCad memmory and all that stuff which I found out is mostly a myth, but the problem could have been they were over charged so I drainded all 7 packs using some motos and a meter conected to the pack in 10A mode, some of the packs are at .5 volts I hope I didnt kill some cells.
    Anyways im having a hard time finding out how many amp hours these batterys are there Tyco no 2998 9.6vNiCad packs for tyco turbo vehicles.... They all have 8 cells in them that are just a bit shorter than AA batterys, im guessing each cell is 1.2v just like a standard nicad, Is there a standard amp hour on most of these RC packs, or the cells in them? The Ryobi drill battery has cells that are much fatter and its 2200mah, the charger for the ryobi is putting out the same voltage and current as the tyco chargers. Now according to what W9 said above im getting that is the tyco packs are not also 2200mah I cant parallel the tycos and ryobi, im not even talking about when charging here im just taling about getting more amp hours
    edited 2012-10-17 21:03
    You can't tell just by the size of the cell. I've got AA size cells that range from 500mAh to at least 1000mAh in NiCads. A quick Google search says the Tyco 2998 battery pack has a 700mAh capacity.
    Sub-C size cells are popular in power tools, they also can vary greatly in capacity. 1500mAh was the low end years ago but I took apart a cheap Chinese drill recently to find that they were a pathetic 800mAh! Nowadays you can get NiMH Sub-C cells over 4,000mAH. Sub-C is the size that you see in RC car packs.
    edited 2012-10-17 21:48
    wow I suck at googling sometimes I went 3 pages in and couldnt find that info. My drill pack is using cells that are a bit shorter than AAs too but a whole lot fatter in diameter where as the tyco pack have about the same diameter as an AA.
    So im still unclear as to wether I can parallel the 9.6v NiCad drill cells along with the tyco packs, for operation and when charging. Im guessing the drill pack would have to be charged separately since it needs to be charged longer.... or at least the drill cells need to keep charging after the tycos packs have stoped somehow?
    edited 2012-10-17 21:53
    Oh also the other thing is when something says it is 700mah that means in a perfect world I would have 1 hour at 700mah and 9.6v correct? Like the batterys voltage shouldnt drop before ive had my 700mah of use? Im just trying to determine when the battery voltage acually starts dropping
  • idbruceidbruce Posts: 6,197
    edited 2012-10-18 02:28
    rwgast_logicdesign
    I am sure the answers to most of your questions can be found from this page: Bruce
    edited 2012-10-18 06:06
    In the past 25 years, battery makers have learned primarily two things.
    A. Make secondary batteries more fragile to charging and discharging. (so the makers sell more batteries, and special chargers)
    B. Never let the public have a generic packaging if it can be avoided. (this they likely learned from Gillette and Schick)
    Are you really wanting NiCd or do you want the newer NiMH. There is quite a bit of difference as NiMH is a technology that is advancing and maybe keeping up with Lithium in power densities.
    It really doesn't matter what you chooose, the more cells you have in series and parallel, the higher the chance that you will burn one up due to a charging or discharging imbalance. That is the really annoying reality of batteries.
    If you want fast easy charging, you might as well buy a system. If you want to DIY, it is best to keep the design simple and go for medium rates of charging.
  • doggiedocdoggiedoc Posts: 2,257
    edited 2012-10-19 04:49
    Nice link Bruce.... thanks.
    idbruce wrote: »
    rwgast_logicdesign
    edited 2012-10-19 04:55
    doggiedoc
    I have another good link laying around somewhere, but I have misplaced it, however the site may no longer exist for that matter. Anyhow it dealt specifically with designing and building power packs, including tips, tricks, and the math involved. If I happen to come across it, I will post it as well.
    Thanks for the thanks.
    Bruce
    edited 2012-10-19 06:21
    Try Battery University for good reading material and Wikipedia.
    www.batteryuniversity.com
    The bottom line about batteries is that they require some idea of what the chemistry is doing. Also, it helps to understand that many of advancements are rather exotic.
    The two main enemies of batteries are heat and deep discharge. In general batteries like to be closer to their fully charged state. Leaving a dead cell around tends to deteriorate faster, though some disagree and claim NiCd and NiMH can sit around without charge.
    NiCds are good, but the NIMH are much better in terms of capacity. I believe that the NiCds might be better for use in rapid discharge; such as electric airplane flight. But the extra capacity of NiMH make the trouble of managing them a bit more worthwhile for the same use.
    Once you get into deciding to go with a battery, the next problem is charge rate. While Lead acid will do well on a trickle charger and maybe even NiCd do well on a trickle charge; the newer chemistries want you to either charge or discharge. But that is merely part of the problem. Lead acid batteries seemed to tolerate a fast charge upon occassion, but new battereis prefer to be first slow charged, then fast charged, and then topped off with a slow charge. This 3 stage charging can be avoided if you provide the right charge rate and make sure your batteries are adequately discharged before charging again.
    My own feelings are that NiCds are on the way toward disappearing. I have decided to get rid of any NiCds I have and to switch to NiMHs. I am still frustrated by Lithium batteries as I have just had enough new or nearly new batteries fail to resent the fact that they are so expensive.
    edited 2012-10-19 16:13
    As I see it, all cells comprising a "pack" (whether series, parallel, or any combination) should be of the same rating and from the same manufacturer - and especially in a charging situation.
    At least in theory, manufacturered battery packs have some quality control to make sure the batteries are matched. But I've read some literature on Lithium Ion batteries varying as much as 30% in actual internal resistances within the same production run.
    It may be that some kinds of batteries are easy to build as uniform cells and others are more difficult. I suspect that Lithium may be one of the more difficult. NiMH uses rare earths coating the anode of the battery that are both expensive and very thin. That kind of technology may make uniformity harder and certainly causes them to be a bit more fragile.
    About once a year, I find myself having to re-read material published about batteries. In the beginning, new technologies tend to claim to have resolved problems. But as time goes by, problems become more obvious. So, literature from manufacturers may not always be truthful about battery performance.
    Every battery maker wants to sell more batteries and there are only two ways to do so - sell better batteries OR make batteries that don't last long. So battery makers sell higher and higher capacity (or claim to) and faster and faster charging (which damages the batteries more).
    If you want rechargible batteries to last long, you need to find the best charge rate and sometime you have make sure you have them discharge enough before you charge. So these days, fancy chargers that may even discharge the battery before charging are required to get the most.
