Parallax Optical Finger Nav sensor in MAKE #32
GordonMcComb
Those who read MAKE Magazine may want to check out issue #32, which just came out, for a simple project built around the Parallax Optical Finger Navigator sensor. It's a keyless lock box that uses finger gestures as the combination. It uses an Arduino as the controller (could easily be substituted with a QuickStart), the sensor, and a Parallax standard servo. And yes, I wrote the article.
I see Parallax has the OFNs on sale right now. These are are very under-rated little critters, and deserve a look-see. The OFN is easy to work with -- it uses I2C interfacing and a very simple command structure -- and has some intriguing possibilities.
-- Gordon
-- Gordon
