Slower Motor for Stingray Robot
Just got these lower-geared motors from Ebay China and verified they are an easy bolt-in swap for the stock motors in the Stingray robot. Yes, I'm finally going to build mine! Video shows relative speeds at ~12V. ~$10 each, pretty nice motors.
http://www.ebay.com/itm/170819379020?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 My seller was wholesale-eshop which doesn't list these currently, but there are others out on Ebay, search "DC Gear Motor 12V 70rpm 37mm High Torque 8kg.cm"
I think the 150rpm motors (~ 2ft/sec) with 14kg-cm torque would be more appropriate for the Stingray. They are 100% faster and have almost twice as much torque as the Chinese ones, still at $24.
According to this the stock Stingray motors (HN-35GMB-310rpm) have a pathetic 1.3kg-cm of torque. If that is accurate then even the cheap Chinese motors are an improvement.
Good questions. What little I know about reliable navigation says slower is almost always better, so that's my direction, Captain!
I agree 350 RPM is way too fast. I am using a pair of these Pololu 100:1 Metal Gearmotor 37Dx57L mm with 64 CPR Encoder on the robot I have under construction. Key specs of the motors at 12 V: 100 RPM and 300 mA free-run, 220 oz-in (16 kg-cm) and 5 A stall. This 2.71"
I wasn't suggesting that 350 rpm was appropriate for the Stingray. I was pointing out that the 350 rpm Pololu motor is rated at the same torque as the 70 rpm eBay motor. I would prefer the 150 rpm motors as they have loads more torque than the 70 rpm eBay motors AND can drive the robot faster. A robot the size of a Stingray begs to be let out into larger areas. It should at least be able to go as fast as a slow walk.
http://embeddedcontroller.weebly.com .
That Stingray tailwheel looks great, but I suspect a small caster will work better there. I'm just using the parts of the Stingray that suit my evil needs.
I should point out that the original Stingray motors were intended for 7.2V, and all motors discussed here are 12V, so there's a bit of apples & oranges going on. I'm planning on using four 18650 Li-Ion batteries for starters.
-MattG
What do you plan to use for encoders? Or are you making your own out of a band-aid box and toothpicks? ( I know how much you like to roll your own)
I can't seem to find the specs for the back output shaft. Diameter / length.
http://www.ebay.com/itm/361086955856
