Parallax now carrying Propeller ASC+
Martin Hodge
In case you missed the announcement. Parallax is now carrying a new version of the Propeller ASC+. The "rev.f" board has the new Arduino header layout and a uSD slot on the back.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/872/List/1/Default.aspx
Glad to see them in the P-lax store.
I have purchased a fairly large number of them over the last two months (just ordered two more yesterday), and I am glad to know they can be purchased at parallax. One small thing to consider, the AUX connector is very useful functionally, but cannot be used when a daughtercard is placed on top. I have now desoldered that connector and soldered a sideways connector more times than I care to think about, so consider having an option for a sideways connector.
P.S. The pdf on Parallax is for Rev e
Bean
Ray
Good on ya, Martin.
Too bad Parallax put it under Basic Stamp.
Store > Microcontrollers > BASIC Stamp Modules (if you hover over the link)
I've sent the proper schematic to Parallax. In the mean time, you can get rev.f on the Wiki.
The original intention for the AUX connector was to provide compatibility for the Ethernet shield, which requires the top six pins for SPI. And for the KVM and VGA daughter cards which use this port while also passing through the Arduino pins unmolested. But if you're not using those items then I agree, RA pins would be much handier there. Next time you need some, drop me an email and I'll solder on a right angle header for you.
Ray
The "new" Arduino layout adds a few more pin.
SDA and SCL on the top row and IOREF and (a blank?) on the bottom row.
The aux connector is completely different.
Maybe gone and replaced with ICSP (?)
Old style shields should still fit.
http://www.engadget.com/2012/07/23/arduino-leonardo-finally-launches/
Doc, you can't survive without one of these new "f'n" boards! =D
The differences, apart from the uSD socket, are the additional 4 pins Cavelamb described. (I'm not aware of any shields that utilize these extra connections at this time.) The .1" aligned row of empty pads along the top row is gone. And the attempt at using a MOSFET to switch AREF for +5v to the ADC's Vref pin has been replaced with a 741G3157 SPDT digital switch.
For now, the f boards are only through Parallax.
The AUX connector is exactly the same. The only change was the labeling from "ICSP" to "SPI". Since those top six pins were never an "In Circuit System Programming" port.
I think this is a really good product for the community and I think it will really help spread the propeller to new users.
(Actually, I kind of want to have one just to show people that are reluctant to try the propeller because it isn't the arduino.)
Ah! Thanks Martin.
I didn't grok that from the site I read.
And congratulations again.
Now, get ASCs in Radio Shack, how about?
Wouldn't that be sweet!
1. What are the pins for D0,CLK,DI,CS for the card reader?
2. Does it read/write uSCHD cards? That is all the local BestBuy seems to stock (16gb!). I'd hate to have to run out and find a non-HD SD card but best to know before banging my head against the wall.
