Parallax now carrying Propeller ASC+ — Parallax Forums
Martin HodgeMartin Hodge Posts: 1,246
edited 2014-04-10 05:53 in Propeller 1
In case you missed the announcement. Parallax is now carrying a new version of the Propeller ASC+. The "rev.f" board has the new Arduino header layout and a uSD slot on the back.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/872/List/1/Default.aspx
    edited 2012-10-09 20:33
    Congratulations!! Micro-SD on the back? Nice touch!!
    edited 2012-10-09 20:46
    Congratulations Martin!
  • doggiedocdoggiedoc Posts: 2,250
    edited 2012-10-09 20:47
    Great job Martin! I've been meaning to tinker with the ones I bought from you. I swear it's on my list!!
    Glad to see them in the P-lax store.
  • ypapelisypapelis Posts: 99
    edited 2012-10-10 04:42
    This is an excellent board Martin, and has quickly become my standard propeller board (something about having the A/D there and being able to throw an empty daughtercard just to make connections, it is very handy).
    I have purchased a fairly large number of them over the last two months (just ordered two more yesterday), and I am glad to know they can be purchased at parallax. One small thing to consider, the AUX connector is very useful functionally, but cannot be used when a daughtercard is placed on top. I have now desoldered that connector and soldered a sideways connector more times than I care to think about, so consider having an option for a sideways connector.
  • BeanBean Posts: 8,129
    edited 2012-10-10 05:16
    Martin, Nice board.
    P.S. The pdf on Parallax is for Rev e
    Bean
  • RsadeikaRsadeika Posts: 3,877
    edited 2012-10-10 05:33
    ...and a uSD slot on the back.
    I am not sure what the description "slot" means. I looked at the rev. f pdf, and did not notice any wiring for the uSD reader, if that is what "slot" is referring to. The other option is, "slot" - solder pads for a uSD reader if you choose to solder one on. If this has a uSD reader on board, I may have to consider this ASC board for my FTm&s project, at least for the slave board part.
    Ray
    edited 2012-10-10 05:36
    Congratulations Martin that's a neat board.
  • cavelambcavelamb Posts: 724
    edited 2012-10-10 05:57
    This is really good news.
    Good on ya, Martin.
    edited 2012-10-10 07:42
    That's super, Martin.
    Too bad Parallax put it under Basic Stamp. :)
    Store > Microcontrollers > BASIC Stamp Modules (if you hover over the link)
    edited 2012-10-10 07:48
    I think Ray's right. These no uSD on the board?
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2012-10-10 09:19
    Trust me, there is a push-in-push-out uSD slot on the back. It is not pictured in Parallax's photo.
    I've sent the proper schematic to Parallax. In the mean time, you can get rev.f on the Wiki.
    960 x 1280 - 351K
    edited 2012-10-10 09:32
    ypapelis wrote: »
    The original intention for the AUX connector was to provide compatibility for the Ethernet shield, which requires the top six pins for SPI. And for the KVM and VGA daughter cards which use this port while also passing through the Arduino pins unmolested. But if you're not using those items then I agree, RA pins would be much handier there. Next time you need some, drop me an email and I'll solder on a right angle header for you.
  • jazzedjazzed Posts: 11,803
    edited 2012-10-10 10:42
    Congrats Martin. It seemed inevitable that this would happen. About time it did!
    edited 2012-10-10 11:02
    Congratulations! The ASC+ is a nice board and this new version with the SD card is even nicer!
    edited 2012-10-10 11:31
    Is the rev.f ASC+ board only going to be sold through Parallax? Since, on your site you only show a rev.e ASC+ board, will the new board become available at some later date? Congratulations, the board really looks good.
    Ray
    edited 2012-10-10 12:18
    Martin, I have a couple of Rev e boards. What's the main difference besides the SD card slot on the back. Perhaps I should order a couple of more :D so I'm not the only kid on the block with an older model. :D:D
    edited 2012-10-10 12:20
    doggiedoc wrote: »
    Don't worry. I have one too! :-)
    edited 2012-10-10 15:30
    doggiedoc wrote: »
    The "new" Arduino layout adds a few more pin.
    SDA and SCL on the top row and IOREF and (a blank?) on the bottom row.
    The aux connector is completely different.
    Maybe gone and replaced with ICSP (?)
    Old style shields should still fit.
    http://www.engadget.com/2012/07/23/arduino-leonardo-finally-launches/
    edited 2012-10-10 16:02
    doggiedoc wrote: »
    Doc, you can't survive without one of these new "f'n" boards! =D
    The differences, apart from the uSD socket, are the additional 4 pins Cavelamb described. (I'm not aware of any shields that utilize these extra connections at this time.) The .1" aligned row of empty pads along the top row is gone. And the attempt at using a MOSFET to switch AREF for +5v to the ADC's Vref pin has been replaced with a 741G3157 SPDT digital switch.
    Rsadeika wrote: »
    Ray
    For now, the f boards are only through Parallax.
    cavelamb wrote: »
    The AUX connector is exactly the same. The only change was the labeling from "ICSP" to "SPI". Since those top six pins were never an "In Circuit System Programming" port.
  • varnonvarnon Posts: 184
    edited 2012-10-10 16:33
    Awesome. I want one... not to use it for anything yet... just to have it.
    I think this is a really good product for the community and I think it will really help spread the propeller to new users.
    (Actually, I kind of want to have one just to show people that are reluctant to try the propeller because it isn't the arduino.)
    edited 2012-10-10 16:40
    I don't have an f'n version but I've had one for a long time and it is a cheap (not cheap, cost-effective and inexpensive) thrill to plug an Arduino shield into it and start writing Spin for it!
    edited 2012-10-10 16:42
    Doh! Just saw U1 uSD on the schematic. Don't know how I missed that before.
    edited 2012-10-10 18:17
    Ah! Thanks Martin.
    I didn't grok that from the site I read.
    And congratulations again.
    Now, get ASCs in Radio Shack, how about?
    Wouldn't that be sweet!
    edited 2012-10-11 02:35
    Congrats Martin!
  • porcupineporcupine Posts: 80
    Reviving old thread; but a couple questions about the MicroSD card, I just got the rev.f ASC+ board.
    1. What are the pins for D0,CLK,DI,CS for the card reader?
    2. Does it read/write uSCHD cards? That is all the local BestBuy seems to stock (16gb!). I'd hate to have to run out and find a non-HD SD card but best to know before banging my head against the wall.
