Schmartboard blow-out! $15 boards with prop!
Schmartboard blow-out! $15 boards with prop!!
http://www.schmartboard.com/index.asp?page=products_special_e
Speaking of which, now that the Quickstart board is here, who among us will use the 40-pin DIP Propeller chips from the mystery bag? Isn't that a rite of passage? Don't let the wife make jewelry out of them, Guys!
Stick one on a Quickstart proto board with a couple capacitors and you have an easy slave propeller for multi-propeller PropForth! Easy-peasy!!
But I dislike barrel plugs as they consume far more space that necessary just to make sure a novice will not get the power reversed. They interfer with making compact designs have well thought out power distribution.
