Spinneret won't mount SD card (it used to just fine)
Electrodude
Hi,
I recently used the 16GB microSD card I use for my spinneret as temporary storage for repartitioning a 16GB flash drive. I repartitioned the SD card with a 8GB FAT32 and a 8GB ext4 partition using fdisk and mkfs under Gentoo. I used Mac OSX's Disk Utility to repartition it to just a FAT32 partition and now the spinneret can't mount it. I use MikeG's server. The demo for version 2 of Kye's SD card driver can read it, but bad things happen if I try even making MikeG's server say that the SD card mount failed. I get lots of random output as if something started attacking the serial buffer. If I let the abort empty the stack and stop cog 0, however, I don't get any random output. Anyone have any idea of what's happening?
I wrapped the driver in S35390A_SD-MMC_FATEngineWrapper.spin where the partition is hard-coded... I assumed a single partitioned SD card for the web server.
Maybe try partition 1?
