SimpleIDE Side files and Makefile
I've noticed that all SimpleIDE projects have a side file which seems to define the properties for the project and the file list. You get new files in your project by either adding a file link or copy into the project. But some of the examples also have a Makefile which looks like it was hand crafted. Is a Makefile required to use SimpleIDE in some cases, or did people add it to allow for use from the command line?
Sorry if this is a basic question, but a Google search didn't turn up anything and the link to the SimpleIDE UserGuide.pdf is broken on page https://sites.google.com/site/propellergcc/documentation/simpleide.
Martin
Martin
By transparent I mean that the user won't need to know anything about make and won't really be able to tell that it is being used. SimpleIDE will be able to generate the makefile from the main C file by a separate utility. A subtle advantage of this approach is that geezers can use the makefile and thus the program will become more universal.
Didn't notice that comment until today.
The link worked for me.
Try this: https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxwcm9wZWxsZXJnY2N8Z3g6NGU1NDU0NDQ5NmZjMjg2Nw&pli=1
I've also attached a .pdf file from my computer.
