SimpleIDE Side files and Makefile — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2012-10-06 17:22 in Propeller 1
I've noticed that all SimpleIDE projects have a side file which seems to define the properties for the project and the file list. You get new files in your project by either adding a file link or copy into the project. But some of the examples also have a Makefile which looks like it was hand crafted. Is a Makefile required to use SimpleIDE in some cases, or did people add it to allow for use from the command line?
Sorry if this is a basic question, but a Google search didn't turn up anything and the link to the SimpleIDE UserGuide.pdf is broken on page https://sites.google.com/site/propellergcc/documentation/simpleide.
Martin
    edited 2012-10-02 13:15
    Martin_H wrote: »
    Martin
    SimpleIDE doesn't require makefiles. The ones that are there are for geezers like me who still remember how to type commands at a prompt! :-)
    edited 2012-10-02 13:39
    OK Thanks. I thought that might be the case.
  • jazzedjazzed Posts: 11,803
    edited 2012-10-03 09:51
    We will probably be enlisting make later as a transparent feature. There are advantages to using it such as incremental compile/link and portability.
    By transparent I mean that the user won't need to know anything about make and won't really be able to tell that it is being used. SimpleIDE will be able to generate the makefile from the main C file by a separate utility. A subtle advantage of this approach is that geezers can use the makefile and thus the program will become more universal.
    Martin_H wrote: »
    Didn't notice that comment until today.
    The link worked for me.
    Try this: https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxwcm9wZWxsZXJnY2N8Z3g6NGU1NDU0NDQ5NmZjMjg2Nw&pli=1
    I've also attached a .pdf file from my computer.
