IR Beacon Tracking
First test using twin TSOP4038 IR receivers to track to a simple LM556 beacon (blue LED on door). Seperately, it uses a Sharp IR distance measuring module as a digital proximity switch. When it gets within 4" of the door it does an about face and drives away for 6 seconds, then repeats the locate & track cycle. Not bad for a first test, I have lots of variables to adjust.
http://www.youtube.com/watch?v=-BKikozfdds
Very nice! How are the IR receivers positioned? Just a simple V arrangement? Any lenses involved? Do tell.
(but where's the plywood? all i see is plastic)
-MattG
-MattG
SteamPunk no doubt.
Hold it right there, Mister! You're the guy who switched Ken's beautiful (ply)wood robot chasses to delrin and started the whole rift!
Anywho, since plastics come from petroleum products, which is from oil, which is (in part) from millions-year-old forests that turned into peat and oozed its way into the ground, your robot is indeed made of wood. And maybe a pterodactyl.
-- Gordon
http://www.youtube.com/watch?v=3rHuFFe6HRc
BTW Your put my IR beacon project to shame. I bought a pair of the Pololu beacon/sensor pairs and started working on simple single point navigation. But I can't reach this level of complexity with a single beacon.
Nice work erco!
-MattG
http://find.botmag.com/111207 and there is more info and specific part recommendations there for anyone seekin' beacon info.
JK, I like your demo. What's next?
TCIII
Lazy more than rich. I've been meaning to build navigation beacons since the first time I saw your 556 timer circuit. I like building robots and don't mind programming, but building boards from scratch always slows me to a crawl. I'm going to switch over to the 4x4 instead of CBA, add more collision sensors, and improve the navigation software. I can use the Pololu beacons to debug it and act as the goal.
The idea is to build a smart "horse" robot that has 4 pin reins that any rider can control. For example I bought a GPS a while back and plan to build a GPS rider. You feed the GPS a way point which acts as a virtual beacon, and the robot will travel there under the direction of the GPS rider. Or you could have a remote control rider that directs the horse, but can't command it to go into the ditch. The 4x4 will be ideal for this sort of thing.
The Basic Stamp 2 should be good at this job, while the GPS functions could under control or a Propeller chip or that brand X MCU I also know how to program.
-- Gordon
That'll cost you a dollar, same as every Ebay referral!
