Starter Kit with 3 amp power?
Ok, I just bought my first propeller in the form of the starter kit, so yes, I am a bit of a newbie here.
I have a 5.5v 3amp power supply that I want to use with it (it is the power supply to the device I want to use the propeller to control).
The specs for the demo board say:
Power requirements: 6-9 VDC, 2A regulator on board
How might I make it ok to use the power supply I have?
Thanks in advance,
Brian
Thanks in advance,
Brian
Welcome to the Prop forum Brian!
Of course the board is regulating down to 3.3V and possibly 5V but you may be able to connect the 5V from your power supply directly to the 6V input as most board have low dropout regulators. I don't know which board you are using though and the 5V that is regulated on the board will be a little bit less than 5V if that doesn't worry you although the 3.3V will be fine.
typical dropout voltage at the max. I of 500 mA is 500 mV (but can be until 1V). At a I of 50mA the dropout voltage is only 110 mV (until 250 mV).
So your 5.5 Volt will be enough if you draw not too much current.
i would defintaley suggest going to wal mart and getting an adjustable wal wart the come in so handy its rediculous. there are two at my local wal mart they both have a buch of interchangable tips (easy to make your own adapter for also) but the 15 dollar one is what you want. it is a 1300mA 1.3amp supply with voltages from 4.5 to 12 and a usb charger...
When you get into the Low-Dropout region of regulation, there is a big jump in current demand. Look again at the curves for Quiescent Current on the PDF. There is nothing wrong with using that region, but it will run hotter.
NOTE- The curve charts in a PDF are more detailed than the text and tables.
The 3 amps rating of the wall wart just means you have 1 amp unusable capacity. If the regulator can only deliver 2 amps, it likely has a thermal shut down for demands in excess of that rating.
Id there is a 2amp load instead of a 50ma load, the quiescent current goes up as well.
It does look like there is a typo at the Propeller Demo Board page and that 2 amps should read 1/2 amp regulator 6-9 volt.
Hmm. I am using the Demo Board and was looking at the 2amp capability of the regulator. If that is a typo (which it seems to be) I probably shouldn't use the 3amp power supply.
It does look like some folks have successfully driven the lights with 3.3 volts, so I may be ok with trying that out.
Thanks for the responses everyone!
Let's see what I can do to start running some programmable lights for Halloween (and Christmas)!
Brian
The 3 amp rating on the power supply is how much you CAN draw from it not how much it forces into anything connected to it. If you had a 500 ma power supply and a device that required 1 amp, there would be a problem.
