Active Suspension
Hi guys, im a student at the electromechanical department in alexandria university, Egypt.
so this is my graduation year and we decided that our graduation project would be "Active Suspension", it detects road profiles and u know "holes and bumbs" and moves the suspension vertically in order to keep a high ride quality, so im in charge of the sensors and how to process the sensor's output, so im gonna need some help with what kind of sensors should i use for detecting the depth of the road? its gonna be mounted at the bottom of the vehicle and actively measures the distance between the vehicle and the road
after all the googling ive done i found that the best option is the ultrasound distance sensor but i have no experience at all with it, so pls guys help me with any recommendations and suggestions, sorry for making it long
(There are commercial equipment out there for measuring roads, mostly for wear management on asphalt, but it's a small market, so really pricy)
I fear that Ultrasonic isn't going to work very well on a moving vehicle. At least not if it moves quickly.
(You will at least have to take the speed into consideration regarding doppler and so on, and it must be pointed forwards. It's too late to detect a bump if it's already at your wheels)
but as this is the type of equipment that you're more likely to be able to source cheaply, it's the way to go for the moment.
I would use at least two sensors, pointing forward in a 45degree or flatter angle, one in front of each front wheel. (pot hole detectors)
A third one, also facing forward, in the centre can be used as a 'general quality' and reference.
What kind of suspension are you going to use?
Personally I prefer the Citro
Erlend
Edit:
You should go for the 'Derivative' part of PID control algorithm, meaning it is only the change rate of the distance that matters. That way you do not need to worry about calibrating distance, changes due to humidity, etc.
i wanna measure the height of the bump as i get closer to it and the sampling rate has to be high, my model is gonna go for 1 meter/sec only though, so putting that in mind which is better laser or ultrasonic or IR sensors?
another thing is, im not gonna measure depth of a flat surface, its gonna be "curvy" so im not sure if the laser sensor is a good idea here since the reflected beam might go somewhere else far away from the receiving end, so im looking forward to see ur suggestions, again
Regards.
edit: guys i was watching a video and seems like there is other suggestions, they are similar in the components needed. they both require a horizontal laser beam and a camera, as the surface gets closer the laser beam becomes "horizontally shorter" and somehow the camera detects the length of the beam
the second method is by detecting the whole beam intensity as light intensity decreases as distance increase, what do u guys think?
what about the laser and the cam thing? can u tell me where can i find more information about that and how to interface that with a servo motor?
[h=3]Robotic Surveyor[/h]
Don't guess. Calculate.
Doesn't the motor have to move the suspension just as quickly as the terrain fluctuates relative to the wheel? If the motor is too slow how does starting early help? Extreme case, let's say you're traveling fast enough that the bump comes and goes under the wheel in 0.1sec but your motor takes 10 seconds to lift. You can start 10 seconds early but what will happen?
Say you have a laser and camera mounted facing the same direction but a few inches apart, and angled towards each other. You have a box 6" away and you angle the laser towards the camera until the laser dot shining on the box shows up in the center of the camera's image. What happens to the laser dot in the camera image if you move the box farther away? Or closer?
You might look at using a Wiimote camera. It operates at 120 fps and works great with a low power infrared laser. also, one camera can sense multiple lasers.
Michael
