Mouse Sensor Kit
I'm trying to write an Arduino program to work with Parallax's Mouse Sensor kit. I've seen a lot of people trying to do something similar with old mice-I think it would be fantastic to get this to work because then we would have standardized the hardware somewhat.
I've succeeded after a fashion. So long as I make slow, smooth movements it appears to function as desired. However, when I make sudden movements, the sensor is often "tricked" - it will say it isn't moving or is moving in the opposite direction at times. It looks almost like an overflow problem, but when I check the status bits for dy & dx, they're 0s.
When I run the basic stamp program with the sensor hooked up to my Boe-Bot, the performance is much more consistent, so it's not a limitation of the hardware. I also noticed that the basic stamp program seems to be more granular-it looks like it returns something besides a 0, 128, 0r 255; where these are the only values I seem to get when using the arduino.
Datasheets and sample programs can be found at the Mouse Sensor Kit product page
Here's what I have so far:
#define sclk 5 //Define pin 5 as clock
#define sdio 6 //Define pin 6 as data
//Mouse sensor register addresses
#define CHNG 0x80
byte stat;
byte readx; //Vallue from sensor: 255 = -1, 128 = 1
byte ready; //Vallue from sensor: 255 = -1, 128 = 1
byte quality;
int dx;
int dy;
int x;
int y;
byte WriteNeg(byte data)
pinMode(sdio,OUTPUT);
for(int i = 0; i < 8; i++)
digitalWrite(sdio,bitRead(data,7));
digitalWrite(sclk,LOW);
delayMicroseconds(50);
digitalWrite(sclk,HIGH);
data = data << 1;
pinMode(sdio,INPUT);
byte ReadNeg()
byte data = 0;
bitWrite(data,i,digitalRead(sdio));
return data;
void WriteAddr(byte address, byte data)
WriteNeg(address|0x80);
WriteNeg(data);
int ReadAddr(byte address)
WriteNeg(address);
delayMicroseconds(100);
return ReadNeg();
void setup()
delay(2000);
Serial.begin(9600);
Serial.print("Program Initializing");
pinMode(sclk,OUTPUT);
Serial.print("\nClock pin set high");
delay(100);
WriteAddr(0xB1,0x80); //Sets resolution to 500 dpi
Serial.print("\nResolution set to 500 dpi");
Serial.print("\nMain program starting\n");
void loop()
stat = ReadAddr(0x16);
if (stat & CHNG != 0)
readx = ReadAddr(0x03);
switch (readx)
case 255:
dx = -1;
break;
case 128:
dx = 1;
break;
case 0:
dx = 0;
break;
x = x + dx;
Serial.print(dx,DEC);
Serial.print("\t");
Serial.print(x,DEC);
Serial.print("\t");
ready = ReadAddr(0x02);
switch (ready)
case 255:
dy = -1;
break;
case 128:
dy = 1;
break;
case 0:
dy = 0;
break;
y = y + dy;
Serial.print(dy,DEC);
Serial.print("\t");
Serial.print(y,DEC);
Serial.print("\t");
quality = ReadAddr(0x04);
Serial.print(quality,DEC);
Serial.print("\t");
Serial.print(stat,BIN);
Serial.print("\n");
I would try MSBFIRST which matches the bit order and sampling bits after the clock is normal serial behavior.
I've used the mouse sensor with my Basic Stamp, but I would be interested in getting this working to increase my options.
Here's my code:
#define sclk 5 //Define pin 5 as clock #define sdio 6 //Define pin 6 as data //Mouse sensor register addresses #define DY 0x02 #define QLTY 0x04 #define STAT 0x16 #define CONF 0x1B #define LORES 0x80 #define CHNG 0x80 #define OFLOW 0x18 #define NEG 0x80 byte stat; byte dx; byte dy; byte quality; byte ovfl; int x; int y; void WriteAddr(byte address, byte data) { shiftOut(sdio,sclk,MSBFIRST,address|0x80); shiftOut(sdio,sclk,MSBFIRST,data); } int ReadAddr(byte address) { int data; shiftOut(sdio,sclk,MSBFIRST,address); pinMode(sdio,INPUT); delayMicroseconds(100); data = shiftIn(sdio,sclk,MSBFIRST); return data; } void setup() { Serial.begin(9600); pinMode(sclk,OUTPUT); digitalWrite(sclk,LOW); delay(100); WriteAddr(CONF,LORES); } void loop() { stat = ReadAddr(0x16); dx = ReadAddr(0x03); dy = ReadAddr(0x02); quality = ReadAddr(0x04); Serial.println(dx,BIN); }I'm going to try the separate power and clock mode to see if I get your initial problem.
#define sclk 5 //Define pin 5 as clock #define sdio 6 //Define pin 6 as data //Mouse sensor register addresses #define CONF 0x1B #define LORES 0x80 #define CHNG 0x80 #define OFLOW 0x18 #define NEG 0x80 byte stat; byte quality; byte ovfl; byte readx; byte ready; int dx; int dy; int x; int y; void WriteAddr(byte address, byte data) { pinMode(sdio,OUTPUT); shiftOut(sdio,sclk,MSBFIRST,address|0x80); shiftOut(sdio,sclk,MSBFIRST,data); } int ReadAddr(byte address) { int data; pinMode(sdio,OUTPUT); shiftOut(sdio,sclk,MSBFIRST,address); delayMicroseconds(100); pinMode(sdio,INPUT); data = shiftIn(sdio,sclk,MSBFIRST); return data; } void setup() { Serial.begin(9600); pinMode(sclk,OUTPUT); digitalWrite(sclk,LOW); delay(100); WriteAddr(CONF,LORES); } void loop() { stat = ReadAddr(0x16); if(stat & CHNG == 0) { } else { if(stat & OFLOW) { ovfl = 10; } readx = ReadAddr(0x03); if(readx & NEG) { dx = -1*(256-readx); } else { dx = readx; } x = x + dx; ready = ReadAddr(0x02); if(ready & NEG) { dy = -1*(256-ready); } else { dy = ready; } y = y + dy; quality = ReadAddr(0x04); Serial.print(dx,DEC); Serial.print("\t"); Serial.print(x,DEC); Serial.print("\t"); Serial.print(dy,DEC); Serial.print("\t"); Serial.print(y,DEC); Serial.print("\t"); Serial.print(quality,DEC); if(ovfl > 0) { ovfl = ovfl - 1; Serial.print("\t"); Serial.print("Overflow"); } Serial.print("\n"); } }
