Mouse Sensor Kit
I'm trying to write an Arduino program to work with Parallax's Mouse Sensor kit. I've seen a lot of people trying to do something similar with old mice-I think it would be fantastic to get this to work because then we would have standardized the hardware somewhat.
I've succeeded after a fashion. So long as I make slow, smooth movements it appears to function as desired. However, when I make sudden movements, the sensor is often "tricked" - it will say it isn't moving or is moving in the opposite direction at times. It looks almost like an overflow problem, but when I check the status bits for dy & dx, they're 0s.
When I run the basic stamp program with the sensor hooked up to my Boe-Bot, the performance is much more consistent, so it's not a limitation of the hardware. I also noticed that the basic stamp program seems to be more granular-it looks like it returns something besides a 0, 128, 0r 255; where these are the only values I seem to get when using the arduino.
Datasheets and sample programs can be found at the Mouse Sensor Kit product page
Here's what I have so far:
#define sclk 5 //Define pin 5 as clock #define sdio 6 //Define pin 6 as data //Mouse sensor register addresses #define CHNG 0x80 byte stat; byte readx; //Vallue from sensor: 255 = -1, 128 = 1 byte ready; //Vallue from sensor: 255 = -1, 128 = 1 byte quality; int dx; int dy; int x; int y; byte WriteNeg(byte data) { pinMode(sdio,OUTPUT); for(int i = 0; i < 8; i++) { digitalWrite(sdio,bitRead(data,7)); digitalWrite(sclk,LOW); delayMicroseconds(50); digitalWrite(sclk,HIGH); delayMicroseconds(50); data = data << 1; } pinMode(sdio,INPUT); } byte ReadNeg() { byte data = 0; for(int i = 0; i < 8; i++) { digitalWrite(sclk,LOW); delayMicroseconds(50); digitalWrite(sclk,HIGH); delayMicroseconds(50); bitWrite(data,i,digitalRead(sdio)); } return data; } void WriteAddr(byte address, byte data) { WriteNeg(address|0x80); WriteNeg(data); } int ReadAddr(byte address) { WriteNeg(address); delayMicroseconds(100); return ReadNeg(); } void setup() { delay(2000); Serial.begin(9600); Serial.print("Program Initializing"); pinMode(sclk,OUTPUT); digitalWrite(sclk,HIGH); Serial.print("\nClock pin set high"); delay(100); WriteAddr(0xB1,0x80); //Sets resolution to 500 dpi Serial.print("\nResolution set to 500 dpi"); Serial.print("\nMain program starting\n"); } void loop() { stat = ReadAddr(0x16); if (stat & CHNG != 0) { readx = ReadAddr(0x03); switch (readx) { case 255: dx = -1; break; case 128: dx = 1; break; case 0: dx = 0; break; } x = x + dx; Serial.print(dx,DEC); Serial.print("\t"); Serial.print(x,DEC); Serial.print("\t"); ready = ReadAddr(0x02); switch (ready) { case 255: dy = -1; break; case 128: dy = 1; break; case 0: dy = 0; break; } y = y + dy; Serial.print(dy,DEC); Serial.print("\t"); Serial.print(y,DEC); Serial.print("\t"); quality = ReadAddr(0x04); Serial.print(quality,DEC); Serial.print("\t"); Serial.print(stat,BIN); Serial.print("\n"); } }
I would try MSBFIRST which matches the bit order and sampling bits after the clock is normal serial behavior.
I've used the mouse sensor with my Basic Stamp, but I would be interested in getting this working to increase my options.
Here's my code:
I'm going to try the separate power and clock mode to see if I get your initial problem.
