TDA7052A Amplifier project (Video) — Parallax Forums
edited 2012-10-08 21:37 in General Discussion
I finally completed my little amplifier project. It uses the TDA7052A 1 watt audio amplifier IC.
I found some nice little 41x71 mm speakers at Mouser that supposedly go down to 100Hz.
A little bigger than a VEHO 360 but sounds a bit better as well...
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-09-29 08:26
    Was it this speaker? Speakers are one thing I will not buy at Mouser/DigiKey because they just don't have anything good for a reasonable price, especially for hobby projects. They're okay if you will be needing 10,000 identical speakers later, but Parts Express and MCMElectronics are much better for HiFi-type stuff.
    Also, the most important parameters of a speaker (Fs, Vas, Qts) are not listed on the PUI datasheet.
    Here is a speaker that's been available on buyout for a long time and will most likely sound much better in your box. This one is new there, and looks like it probably would be available for project customers. I have a few of these and they are fantastic - highly recommended.
    edited 2012-09-29 08:46
    Yes, the PUI speaker is the one I used. Parts Express does seem to have a good selection of speakers.
    The PUI speaker uses a neodymium magnet and only weighs 38 grams (~ 1.4 ounces) - much lighter than ferrite speakers
    Thanks for the links!
    - Ron
    edited 2012-09-29 09:04
    The last one I linked is NdFeB. I also have some Neodymium subwoofer drivers from PE (TB W6-1139si) that I used to have in my car before I decided to sell it. They're not particularly light, but I think the ferrite version of the same speakers weigh about 10lbs. I had never heard a good pipe organ rendition from a 6" speaker before getting these.
    edited 2012-09-29 16:39
    Ron,
    That's WAY too many components. :)
    Very Nice, thanks for sharing.
    I made a second amplifier in a smaller project box.
    The smaller box uses 4 AAA batteries instead of AA.
    EDIT: video removed
