TDA7052A Amplifier project (Video)
I finally completed my little amplifier project. It uses the TDA7052A 1 watt audio amplifier IC.
I found some nice little 41x71 mm speakers at Mouser that supposedly go down to 100Hz.
A little bigger than a VEHO 360 but sounds a bit better as well...
Also, the most important parameters of a speaker (Fs, Vas, Qts) are not listed on the PUI datasheet.
Here is a speaker that's been available on buyout for a long time and will most likely sound much better in your box. This one is new there, and looks like it probably would be available for project customers. I have a few of these and they are fantastic - highly recommended.
Yes, the PUI speaker is the one I used. Parts Express does seem to have a good selection of speakers.
The PUI speaker uses a neodymium magnet and only weighs 38 grams (~ 1.4 ounces) - much lighter than ferrite speakers
Thanks for the links!
- Ron
That's WAY too many components.
Very Nice, thanks for sharing.
The smaller box uses 4 AAA batteries instead of AA.
EDIT: video removed
