Help with system clock!
I found this file, and Setting up requires me to set a value to constant, however I need to be in the number of system clocks, and the max is 65536 clocks, but I don't understand how to do that. Any help at all would be greatly appreciated. I'm pasting the source code directly from the post, and thanks to David Voss for writing it, but what I need to give a value is PWM_RES, but like I said, I don't know how to give it a value that represents system clocks.
Module: pwm.S, v.0.1, 16 August 2012
Written by: David Voss, Tree of Life Foundation Renewable Electronics,
Patagonia, AZ
Target: Parallax Propeller P8X32A, prop-gcc, memory model = cog
Purpose: System Clock Speed PWM driver with (2) outputs
PAR holds the hub RAM address of the [2] 16-bit duty cycles. If you only need
1 PWM output, don't #define PWM_B_PIN in the header file, and the code will be
a little smaller.
Software stepping of the remaining bits of the (max) 16-bit duty cycle is
implemented to increase the duty cycle resolution while still having a high PWM
rate (short PWM period). To implement this, both the PWM resolution and the PWM
native resolution should be a power of 2. If you don't need this, comment out
#define PWM_STEPPING in the header file, and the code will be a lot smaller.
The following symbols should be #defined in the processor-specific header file:
PWM_A_PIN
PWM_B_PIN (if implemented)
PWM_RES // In System Clocks (max = 65536)
#ifdef PWM_STEPPING
PWM_NATIVE_RES // In System Clocks (min = 256 ==> 391 kHz)
PWM_STEPPING_BITS // = log2(PWM_RES) - log2(PWM_NATIVE_RES)
#endif
#include "main.h" // Pin assignments, PWM resolution, and
// #define PWM_STEPPING (or not) are here
#define CTR_PWM_MODE %0_00100_000
#define dutyA_ptr PAR
#define dutyA OUTB // Save a little Hub RAM...
#define periodStart DIRB // ""
.org 0
.cog_ram
pwm_driver: movs CTRA, #PWM_A_PIN // Set the output pin
movi CTRA, #CTR_PWM_MODE // Set counter mode to PWM
mov FRQA, #1 // Set Frequency to System Clock
or DIRA, diraSet // Set data direction register
#ifdef PWM_B_PIN
mov dutyB_ptr, PAR // PAR is a ptr to PWMmbox {
add dutyB_ptr, #2 // unsigned short DutyA;
// unsigned short DutyB; }
movs CTRB, #PWM_B_PIN
movi CTRB, #CTR_PWM_MODE
mov FRQB, #1
#endif
mov periodStart, CNT // Initialize start from the
#ifdef PWM_B_PIN // system counter
add periodStart, halfPeriod
#else
add periodStart, period
#endif
pwm_loop:
#ifdef PWM_STEPPING
rdword unsteppedDutyA, dutyA_ptr
mov carryA, unsteppedDutyA
shr unsteppedDutyA, #PWM_STEPPING_BITS
shl carryA, #(32 - PWM_STEPPING_BITS)
mov steppingCtr, steppingCount
#else
rdword dutyA, dutyA_ptr
#endif
#ifdef PWM_B_PIN
#ifdef PWM_STEPPING
rdword unsteppedDutyB, dutyB_ptr
mov carryB, unsteppedDutyB
shr unsteppedDutyB, #PWM_STEPPING_BITS
shl carryB, #(32 - PWM_STEPPING_BITS)
#else
rdword dutyB, dutyB_ptr
#endif
#endif
#ifdef PWM_STEPPING
native_pwm_loop:
mov dutyA, unsteppedDutyA
add accumulatorA, carryA wc
if_c add dutyA, #1
#endif
#ifdef PWM_B_PIN
waitcnt periodStart, halfPeriod // Start PWM B 180 deg out
#else // of phase from PWM A to
waitcnt periodStart, period // reduce electrical noise
#endif
neg PHSA, dutyA
#ifdef PWM_B_PIN
#ifdef PWM_STEPPING
mov dutyB, unsteppedDutyB
add accumulatorB, carryB wc
if_c add dutyB, #1
#endif
neg PHSB, dutyB
#endif
#ifdef PWM_STEPPING
djnz steppingCtr, #native_pwm_loop
#endif
jmp #pwm_loop
#ifdef PWM_B_PIN
diraSet: .long (1 << PWM_A_PIN) + (1 << PWM_B_PIN)
#ifdef PWM_STEPPING
halfPeriod: .long PWM_NATIVE_RES / 2
#else
halfPeriod: .long PWM_RES / 2
#endif
#else
#ifdef PWM_STEPPING
period: .long PWM_NATIVE_RES
#else
period: .long PWM_RES
#endif
#endif
#ifdef PWM_STEPPING
steppingCount: .long 1 << PWM_STEPPING_BITS
steppingCtr: res 1
unsteppedDutyA: res 1
accumulatorA: res 1
carryA: res 1
#endif
#ifdef PWM_B_PIN
dutyB_ptr: res 1
dutyB: res 1
#ifdef PWM_STEPPING
unsteppedDutyB: res 1
accumulatorB: res 1
carryB: res 1
#endif
#endif
One comment makes it look like it needs to be a power of 2 also.
How lone will your ON time be?
