So I got this Maker Bot...very cool, warrants a Propeller! — Parallax Forums
Ken GraceyKen Gracey Posts: 7,419
edited 2012-10-01 17:11 in General Discussion
Hey all,
Seen lots of discussion around here about 3D printing so I finally brokered an ELEV-8 hardware (plus some other cool stuff) trade somewhere for a Replicator. Having lots of experience with the reverse process of milling, at first look I can really appreciate the ability to make parts that can't even be milled [easily, without 4th and 5th axis] and to get the job done quickly without fixturing headaches. I'm using 1.8mm ABS and certainly experienced some startup issues with nozzle trouble, bed heating issues to hold the part, etc. None of this was a big deal and I think it's mostly behind me but it certainly owned a few evenings.
And wow, does this device warrant a Propeller! It's great how it runs files from an SD card and that it isn't saddled with a PC. The LCD works fine for basic stuff, but imagine how a Propeller could improve the product. Think about a slick video display with a mouse for navigation. The user interface could be really efficient, easy, and visual by showing the navigation structure and monitor all together. And of course with the Propeller it could talk to you.
I've got a project in mind for MakerBot as soon as I figure out how to get Sketchup to do what I want to do, drawing a nose cone for 4" ABS pipe. I know it's a trivial effort, but I haven't had the time to sit down and do this yet. Instead I've suffered berating comments from my kids who are running circles around me with Thingiverse files. Below you can see a couple of recent parts we printed.
Both Nick and Kevin have these machines at Parallax, but they have the PrintrBot model from Brook http://printrbot.com, another successful KickStarter project. Great for prototyping.
I'm interested in learning what others are doing with their 3D printers. Are you using them, or are they sitting idle? Have you solved any little (or big) problems with them?
  • NWCCTVNWCCTV Posts: 3,629
    edited 2012-09-21 19:36
    Ken, Although I do not yet own one, I have my eye on a couple and am hoping to pick one up soon. I really doubt that it will set idle, at least for a while on my end!!! I plan to use it to replace broken RC Car and Heli parts that are forever breaking due to unusual use!!! I also will be using it to create parts for my never ending robot project(s). Once my ADD kicks in it may set, but I know I will always go back to it! Which do you reccomend, the MakerBot or the PrintrBot and why?
  • W9GFOW9GFO Posts: 4,010
    edited 2012-09-21 19:44
    Use the "Follow Me" tool. It is in the large tool palette. To see it:
    View - Tool Palettes - Large Tool Set
    Draw the shape that you want to revolve, make sure that it is a face. Then draw a circle to serve as the path that the face will "follow". The size of the circle is irrelevant. I usually draw it large enough so that it won't intersect any part of the model. Also set the number of segments in the circle to a number that makes it smooth enough for your needs. If you want it to be a smooth as possible when printing, set the number of segments equal to the circumference of the part in millimeters. It is very important that the center of this circle lie on the same plane as the face that will be revolved and on the axis of rotation. The circle is of course perpendicular to the axis of rotation that you want.
    Here's the trick to using the follow me tool. Select the circle first, then click on the Follow Me tool, then click once on the face that you want to revolve. That's it.
    To be more on topic - Yes! Absolutely, I wish that there was a Propeller solution to running the MakerBot. It could be so much better. Mine has sat idle from time to time, but not for long. I just used it last night to make some robot parts. Last week I used it to make a part to fix my outboard motor.
    edited 2012-09-21 19:48
    @NWCCTV It's too early to say which one I recommend. I think that the first question you need to ask yourself is whether or not you are interested in assembling it yourself. If you are, PrintrBot is a great choice. If you want a turnkey project, Replicator is it (or the UP). I'll have to really compare notes with Kevin and Nick to answer the question, however. Once I get up to speed with MakerBot and can talk to Kevin/Nick about it better than a babbling idiot then we'll be able to give a better opinion. I was at MAKE Magazine in Sebastopol, CA about two weeks ago and they had every single 3D printer on the market in their shop for a hands-on review and comparison. Their work should provide a fairly clear picture of the options right now.
    Your application sounds great, though - small parts for R/C stuff and robots seems like the ideal fit. I'll want to build some prototype parts that we may put into the CNC mill with aluminum, and to make some parts for personal projects like the GPS boat.
    There's a whole lot of excitement around these printers right now. Just today I heard a story on NPR's "Science Friday" about how some scientists are printing with live cells, making small pieces of organs, and then putting them into people where they grow on their own [hopefully]. I realize I condensed tons of research into a single statement, but there's a lot of applications here that haven't been fully identified. Thingiverse certainly shows what's going on at least with ABS and PLA. http://www.sciencefriday.com/segment/06/22/2012/can-3d-printers-reshape-the-world.html seems to be the story, though I heard it today (and not last June).
    Should be a lot of fun.
    @Rich: this is in the Replicator G software?
    edited 2012-09-21 19:49
    Ken,
    'So glad to hear you got your Replicator working! I know you'll have a lot of fun with it.
    Despite the sheer fun of making stuff with it, my MakerBot sits mostly idle, I'm sorry to say. I've made two useful items with it: a set of extensions for a bike rack and a tool for installing lenses in the TSL1401-DB modules. Having said that, however, I have no complaints about its performance, especially after Rich (W9GFO) sent me his very sturdy MakerBot-produced extruder. But, by comparison, the Epilog laser cutter I purchased prior to the MakerBot is by far the more useful -- and productive -- shop tool.
    edited 2012-09-21 19:53
    Ken Gracey wrote: »
    No that's in SketchUp.
    edited 2012-09-21 19:56
    @Phil, yeah, I think about the laser cutter quite a bit while using the Replicator. I'll use this to print the nose cones for by robo cataract that we discussed in Port Townsend. I'm telling ya, it seems like my project time is getting less and less frequent. Maybe I should just take a few weeks off of Parallax and build the things I'm dreaming of. . . but wait, I'm going to Washington D.C. next week. When I get back I'll get into this project in earnest.
    I think the kids in my robot class will really like this tool. I'll give them the challenge of drawing a part and making it on the Replicator.
    edited 2012-09-21 19:57
    W9GFO wrote: »
    Thanks Rich, that'll be a time saver. I'll try it right now.
    edited 2012-09-21 20:03
    Let me know if you have any questions.
    edited 2012-09-21 20:06
    Ken Gracey wrote:
    Maybe I should just take a few weeks off of Parallax and build the things I'm dreaming of. . . but wait, ...
    Just between the two of us, I could arrange a kidnapping if you're interested. (Oh wait, this is a public forum, isn't it? 'Just kidding!) Psst! Ken, call me. We can still make it happen.
    edited 2012-09-21 20:55
    Let's get our Propeller projects on Thingiverse. Here's one http://www.thingiverse.com/thing:14943 but we need many more.
  • max72max72 Posts: 1,155
    edited 2012-09-22 09:21
    You can check kisslicer as an alternative software.
    I really like it.
    The author has been seen around in the prop area (maybe F32 rings a bell?), and in the kisslicer forum there is also a bleeding edge alpha.
    I uploaded a propeller platform "x" support but my parts disappeared. Have to upload them again.
    Massimo
    edited 2012-09-22 15:55
    Ken:
    I have a prusa v2 partially assembled. Only need the time for the jhead and electronics.
    I have done prototype pcbs to use a prop and the existing pololu drivers although I did my own driver pcb based on the A4982/4 IIRC (tssop28) too.
    Just have not had the time to continue (just like the quadcopter) - both half finished.
    Hopefully that should change in a week or so time.
  • vanmunchvanmunch Posts: 568
    edited 2012-09-23 21:54
    I've had my Replicator since May and it's letting me do projects that I couldn't do before. I really enjoy it, but it makes you want to get one of those commercial models. :)
    I've been using the PE (~$99) Alibre for the CAD software and it works well enough for what I need and my laptop can handle. You can even try their full version for 30 days.
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-09-23 22:07
    Given the general s***storm going around because of the non-oshw Makerbot 2, I am leaning as far away from makerbot as I can. You can read more at http://blog.makezine.com/2012/09/22/makerbots-mixed-messages-about-open-source-their-future/
    edited 2012-09-24 01:01
    Note that Makerbot Industries is also the company that runs Thingiverse...
    A lot of talented people are removing their creations from that site these days.
    If you want something from that site, download it NOW, it may not be available for much longer.
    edited 2012-09-28 07:58
    It has taken me awhile to get back to this as I needed to ponder what all the fuss is about.
    These guys patented a bit of add-on hardware, a pneumatic table to increase production. So everyone gets in a huff about them not being loyal to 'open source'.
    What I really love about the 3D printing is the rather sophisticated open source software. It seems to me that restricting people to not having patents for hardware is rather idealistic and simple greed from those that want everything that they can get for free.
    In other words, it is a shame. We all have to eat. There are good reasons for getting a patent. It just is not the same as shutting people out of learning computers with pricy software.
  • graffixgraffix Posts: 389
    Check out seemecnc.com. It's a new favorite of mine. They have some cheaper printers and a new delta configured one.
