PBasic's MIN and MAX operator precedence. — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2012-09-18 21:07 in BASIC Stamp
In many programming languages MIN and MAX are functions, so the order of operations is clear. But in PBasic they are binary operators, so I assume they have operator precedence. Look at this code for example:
byte a
byte b
byte c
a = 1
b = 2
c = 3
// All MAX is a slam dunk, it should display 3
DEBUG a MAX b MAX c
// If this is evaluated left to right it should output 2.
DEBUG a MAX b MIN c
// But what happens when you mix in other mathematical operators?
DEBUG a MAX b + 1 MIN c
// What about multiply which takes precedence over other operators?
DEBUG a MAX b * 2 MIN c
Basically, my question is how do MIN and MAX fit into the order of operators precedence?
    edited 2012-09-18 14:24
    There is no operator precedence in PBASIC: evaluation is strictly left-to-right unless modified by parentheses.
    edited 2012-09-18 16:25
    Thanks Phil, that explains why I couldn't seem to find anything about it in the manual. It also explains my odd bug.
    I can't believe I've been using PBasic for six years and hadn't noticed that by now. I always assumed it was like other languages which attempt to reproduce the mathematical precedence. Since I tend to avoid compound expressions and heavy math in PBasic I've gotten lucky up to now.
    edited 2012-09-18 17:37
    You'd think slam dunk:
    [FONT=courier new][SIZE=1]a = 1
    b = 2
    c = 3
    DEBUG a MAX b MAX c
    [/SIZE][/FONT]
    but the answer is 1, not 3. That is because the MAX operator sets a ceiling.
    You can think of it as,
    y = x MAX 3
    and that is either x or 3, whichever is less. So 3 is the ceiling.
    Okay, but it is equally true that
    y = 3 MAX x
    is either x or 3, whichever is less. The same as above. The operator is said to be commutative. So with your set of values a=1, b=2 and c=3, the MAX operator ends up picking the minimum value. Tricky huh?
    edited 2012-09-18 17:58
    OK I was completely confused. I thought these were like the C functions of the same name, but it sounds like they are reversed. In C max (1, 3) returns 3, while min(1, 3) returns 1. I have a minor rewrite to do.
    edited 2012-09-18 20:55
    Right, quite the opposite of what you would expect from the mathematical perspective of finding the max or min of a pair or set of numbers. It is more helpful to think of it in the context of process control, where you need to hold a variable to values between a max and a min.
    I like to think of MAX as "but no more than" and MIN as "but no less than." Same goes for Spin, but at least its operators are more intuitive.
