my DNAxxx program — Parallax Forums
my DNAxxx program
RsadeikaRsadeika Posts: 3,902
edited 2012-09-24 10:07 in Propeller 1
I am trying to create a DNA board specific program. I created a separate file, dnsSD.c, that will hold mount() and List(), to start with. The main file is DNAxxx.c which is a UI that will call the specific functions, in this case mount(), and List(). So far the project compiles without errors, but when I request List(), nothing happens, the program just hangs. So first you use mountSD to mount() which seems to work, then ll to List() which just hangs.
I would appreciate if somebody would look at this and see what I am doing wrong.
Ray
DNA.zip 18.9K
    edited 2012-09-12 08:16
    Rsadeika wrote: »
    Ray
    You don't really need the mount code if you put the SD pin definitions in your board .cfg file. The library will use the settings from the .cfg file to mount the SD card. This will let your program run on any board with an SD card slot not just the DNA board.
  • RsadeikaRsadeika Posts: 3,902
    edited 2012-09-12 08:58
    I looked at the dna.cfg file, that I have, but I am not sure how to achieve what you are recommending. I do not want to make things worse by making changes when I do not know what I am doing.
    Ray
  • jazzedjazzed Posts: 11,803
    edited 2012-09-12 09:19
    Rsadeika wrote: »
    Recommended reading.
    https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxwcm9wZWxsZXJnY2N8Z3g6NWJlNzM0NzBlODZiYzJkMQ&pli=1
    Read sections 5 through 7. The simplest way to add SDcard is mentioned in the very last paragraph of section 7.
    For example add these to your config file:
      sdspi-do: 0
      sdspi-clk: 1
      sdspi-di: 2
      sdspi-cs: 3
    Martin offers these pages for DNA.
    http://mghdesigns.com/wiki/dna:start
    The dna.cfg file seems complicated, but it is just a version that uses the loader's expression parser.
    http://mghdesigns.com/wiki/dna:dna.cfg
    edited 2012-09-12 09:26
    Below is what is in the .cfg file already, so I am not sure what has to be changed?
    Ray
    # Default SPI config
    spi-base: 0
    sd-driver: sd_driver.dat
    sdspi-do: {spi-base} + 0
    sdspi-clk: {spi-base} + 1
    sdspi-di: {spi-base} + 2
    sdspi-cs: {spi-base} + 3
    edited 2012-09-12 09:29
    Rsadeika wrote: »
    Ray
    spi-base: 0
    Nothing needs to be changed. This should work just fine as long as the SD card is connected with DO=0, CLK=1, DI=2, CS=3.
    edited 2012-09-12 09:38
    Just to verify, I just ran filetest.c with the mount() deleted, and the List() function works, lists all the files on the SD. Now, with the mount() function code removed, that should free up some bytes. I wonder what else can be removed in the filetest.c example, and still run as expected?
    Ray
    edited 2012-09-12 09:50
    Rsadeika wrote: »
    Ray
    Probably nothing more can be removed. It's just the mount parameters that are set by values in the .cfg file.
    edited 2012-09-12 12:21
    In the zip file I reworked the filetest.c program a little. I moved all of the functions into the dnaSD.c file, so it would be a separate file and easier to edit, less code to look at in the main file. I removed the mount() function code, I have it in another place for viewing as a reference. And the project works as expected.
    Now I am thinking about including some code for using the RTC, not sure how I am going to have it appear in the UI. At the MGH Designs web site they refer you to Roy Eltham's Spin driver for the Seiko RTC, I looked at the code, and I am not sure how that will work for me. Are their any examples of I2C, and how to use it with C? I guess if look at some good examples of, how to use I2C code, maybe I can figure it out. Any ideas will be appreciated.
    Ray
    edited 2012-09-12 13:42
    The I2c quest. I am using David Betz example for ADC test, but I am lacking some info. I was looking for DetectRTCChip() but did not find a function. I did not find the DetectAdcChip() function either. So how do I go about checking for the RTC chip that is on the DNA-RTC board? The program below got past the BootOpen, I am making some headway? I guess I need some I2C code for checking if the S-35390A RTC is there.
    Ray
     * @file testI2C.c
     * This is the main testI2C program start point.
    #include <stdio.h>
    #include <propeller.h>
    #include <unistd.h>
    #include <i2c.h>
    #define DeviceID 0b0110_0000 // According to S-35390A RTC Driver Roy Eltham
     * Main program function.
    int main(void)
        I2C *bus;
        waitcnt(CNT + CLKFREQ);
        if (!(bus = i2cBootOpen()))
            printf("error: Can't open boot i2c bus.\n");
            return 1;
        printf("Got past the bootopen check\n");
        return 0;
    edited 2012-09-12 13:54
    Rsadeika wrote: »
    Ray
     * @file testI2C.c
    #include <stdio.h>
    #include <unistd.h>
    #include <i2c.h>
    int main(void)
        I2C *bus;
            return 1;
        return 0;
    This is all the DetectAdcChip function does:
    int DetectAdcChip(I2C *bus, int address)
        int retries = I2C_RETRIES;
        while (--retries >= 0) {
            if (i2cRead(bus, address, NULL, 0, TRUE) == 0)
                return 0;
        return 1;
    edited 2012-09-12 14:15
    I am getting an error on:
    testI2C.c:19:19: error: 'I2C_RETRIES' undeclared (first use in this function)
    Where is I2C_RETRIES? I guess it is not in <i2c.h>? Slowly, but ...
    Ray
     * @file testI2C.c
    #include <stdio.h>
    #include <unistd.h>
    #include <i2c.h>
    #define DeviceID 0b01100000 // According to S-35390A RTC Driver Roy Eltham
    #ifndef TRUE
    #define TRUE 1
    #define FALSE 0
    #endif
    int DetectRtcChip(I2C *bus, int address)
                return 0;
        return 1;
    int main(void)
        int rtcAddr;
        I2C *bus;
            return 1;
        if  (DetectRtcChip(bus, DeviceID) == 0)
            rtcAddr = DeviceID;
        else
            printf("Error: no RTC chip found\n");
            return 1;
        return 0;
    edited 2012-09-12 14:53
    Rsadeika wrote: »
    Ray
     * @file testI2C.c
    #include <stdio.h>
    #include <unistd.h>
    #include <i2c.h>
    #ifndef TRUE
    #define TRUE 1
    #define FALSE 0
    #endif
                return 0;
        return 1;
    int main(void)
        int rtcAddr;
        I2C *bus;
            return 1;
            rtcAddr = DeviceID;
        else
            return 1;
        return 0;
    Add something like this:
    /* maximum number of retries */
    #define I2C_RETRIES    5
    edited 2012-09-12 15:36
    Here is how far I got, I do not get any errors, but I also do not get any valid data. Anybody see any glaring code errors, or programming mistakes? For some reason the program below no longer works with CMM, I have to use LMM. I also have it checked for 32bit Double.
    Ray
     * @file testI2C.c
    #include <stdio.h>
    #include <unistd.h>
    #include <i2c.h>
    #ifndef TRUE
    #define TRUE 1
    #define FALSE 0
    #endif
                return 0;
        return 1;
    int RtcIn(I2C *bus, int address, int buffer[7])
        i2cRead(bus, address, buffer[0], 0, TRUE);
        return 0;
    int ConvertFromBCD(int value)
        int result;
        result = ((value / 16) * 10) + (value << 16);
        return (result);
    int main(void)
        int rtcAddr;
        I2C *bus;
            return 1;
            rtcAddr = DeviceID;
        else
            return 1;
        printf("rtc[0] = %g\n", ConvertFromBCD(RtcIn(bus,rtcAddr,0)));
        printf("Got to the last of code.\n");
        return 0;
    edited 2012-09-13 06:11
    The RTC program works, partially. Not sure if it is a bug in the spin2cpp translation, or it is a bug in Roy Eltham's program. Something is wrong with the time clock part, the date part seems to work. First, I am using the tools provided by ersmith, Roy Eltham, and James Burrows, for the RTC program, the other program which I started was not working out for me, not enough experience with C.
    Basically, in the UI you have these commands: help, time, date, day, month, year, quit. As mentioned the time command does not work. You have to set the DateTime manually in the program with the rtc1_Setdatetime() command which at the moment contains some irrelevant data. I just wanted to test out the RTC part of the DNA board to see if it really works.
    Once the time clock part gets fixed then I will probably incorporate this into the DNAxxx(filetest) program.
    Ray
    edited 2012-09-13 09:33
    Rsadeika wrote: »
    You should call rtc1_Update() somewhere in your while loop such as after gets(buffer). Otherwise the time and date will not change when read by your UI.
    Another thing I noticed is that basic_i2c_driver.c relies heavily on the code running slowly. CMM "apparently" works, but LMM does not. By apparently, I mean that it's more or less an accident that it works and a higher clock rate or other performance improvements might make the driver fail.
    edited 2012-09-13 10:01
    Well, I found the problem, my ability to follow instructions.
    //Set date time: Month,day,year,DOW,min,seconds
    //DOW - 0-Sun,1-Mon,2-tue,3-Wed,4-Thur,5-Fri,6-Sat
    rtc1_Setdatetime(9,13,12,5,12,51);
    Once I put in the correct Setdatetime() values, the program runs as expected.
    For a more ambitious project I was thinking, use the RTC lib, in a thread, and have it update from the hardware RTC. Then of course you have to figure where you would update the hardware RTC from, and of course if someone using a different RTC ...
    Now I have to figure out how I will incorporate the RTC program into the DNAxxx(filetest) program.
    <edit> I also noticed that if you use printc.c program, it screws the output to the screen. Also, if you check the Simple printf, that also screws up the output to the screen. <edit>
    Ray
    edited 2012-09-13 10:33
    What printc.c program are you using?
    As for RTC, you could try something like below to use the built-in unix time facilities.
    This is obviously not for the DNA board, I use it on my tiny Gamebaby LCD box, and it has a PASM driver that is accessible via GbI2C_rtc_* function calls. I call RTC_init() from the main program at startup.
      * @file RTC1338.c
     #include <sys/rtc.h>
     #include <sys/time.h>
     #include <time.h>
     #include "GbI2C.h"
     #include <stdio.h>
     // RTC year is only 0-99. Unix computing epoc is Jan 1, 1970
     #define YEARADJUST 70
     static time_t mytime;
     int RTC_setTime(const struct timeval *tv)
         unsigned char ones, tens;
         struct tm *t = localtime(&tv->tv_sec);
         mytime = tv->tv_sec;
         printf("%02d:%02d:%02d ",t->tm_hour, t->tm_min, t->tm_sec);
         printf("%02d-%02d-%04d %d %d\n",t->tm_mon, t->tm_mday, t->tm_year, t->tm_wday, tv->tv_sec);
         printf("RTC_setTime Seconds = %10d TimeStamp %s\n", mytime, asctime(t));
          * write rtc register fields.
         /* make sure seconds are encoded as BCD */
         ones = t->tm_sec & 0xf;
         tens = (t->tm_sec/10) & 0x7;
         t->tm_sec = (tens << 4) + ones;
         /* CH bit is 0 by now. Should be to keep timer going */
         GbI2C_rtc_writeReg(GbI2C_RTC_SECOND, t->tm_sec);
         /* make sure minutes are encoded as BCD */
         ones = t->tm_min & 0xf;
         tens = (t->tm_min/10) & 0x7;
         t->tm_min = (tens << 4) + ones;
         GbI2C_rtc_writeReg(GbI2C_RTC_MINUTE, t->tm_min);
         /* make sure hours are encoded as BCD 24 hour time */
         ones = t->tm_hour & 0xf;
         tens = (t->tm_hour/10) & 0x3;
         t->tm_hour = (tens << 4) + ones;
         /* 24 hour bit is 0 by now */
         GbI2C_rtc_writeReg(GbI2C_RTC_HOUR, t->tm_hour);
         /* make sure week days are encoded as BCD */
         t->tm_wday &= 0xf;
         GbI2C_rtc_writeReg(GbI2C_RTC_DAY, t->tm_wday);
          /* make sure month days are encoded as BCD */
         ones = t->tm_mday & 0xf;
         tens = (t->tm_mday/10) & 0x3;
         t->tm_mday = (tens << 4) + ones;
         GbI2C_rtc_writeReg(GbI2C_RTC_DATE, t->tm_mday);
         /* make sure months are encoded as BCD */
         ones = t->tm_mon & 0xf;
         tens = (t->tm_mon/10) & 0x1;
         t->tm_mon = (tens << 4) + ones;
         GbI2C_rtc_writeReg(GbI2C_RTC_MONTH, t->tm_mon+1);
          /* make sure years are encoded as BCD */
         ones = (t->tm_year-YEARADJUST) & 0xf;
         tens = ((t->tm_year-YEARADJUST)/10);
         t->tm_year = (tens << 4) + ones;
         GbI2C_rtc_writeReg(GbI2C_RTC_YEAR, t->tm_year);
         return 0;
    int RTC_getTime(struct timeval *tv)
         struct tm t;
         /* read all rtc registers */
         GbI2C_rtc_readRegs();
         /* get rtc register fields */
         t.tm_sec  = GbI2C_rtc_getReg(GbI2C_RTC_SECOND);
         t.tm_min  = GbI2C_rtc_getReg(GbI2C_RTC_MINUTE);
         t.tm_hour = GbI2C_rtc_getReg(GbI2C_RTC_HOUR);
         t.tm_wday = GbI2C_rtc_getReg(GbI2C_RTC_DAY);
         t.tm_mday = GbI2C_rtc_getReg(GbI2C_RTC_DATE);
         t.tm_mon  = GbI2C_rtc_getReg(GbI2C_RTC_MONTH)-1;
         t.tm_year = GbI2C_rtc_getReg(GbI2C_RTC_YEAR);
         t.tm_sec  = ((t.tm_sec  >> 4) & 7)*10 + (t.tm_sec  & 0xF);   // bcd conversion
         t.tm_min  = ((t.tm_min  >> 4) & 7)*10 + (t.tm_min  & 0xF);   // bcd conversion
         t.tm_hour = ((t.tm_hour >> 4) & 1)*10 + (t.tm_hour & 0xF);   // bcd conversion
         t.tm_wday = t.tm_wday & 0x7;
         t.tm_mday = ((t.tm_mday >> 4) & 3)*10 + (t.tm_mday & 0xF);   // bcd conversion
         t.tm_mon  = ((t.tm_mon  >> 4) & 3)*10 + (t.tm_mon  & 0xF);   // bcd conversion
         t.tm_year = (t.tm_year >> 4)*10 + (t.tm_year & 0xF);         // bcd conversion
         t.tm_year = t.tm_year + YEARADJUST;
         mytime = mktime(&t);
         tv->tv_sec = mytime;
         tv->tv_usec = 0;
         printf("%02d:%02d:%02d ",t.tm_hour, t.tm_min, t.tm_sec);
         printf("%02d-%02d-%04d %d %d\n",t.tm_mon, t.tm_mday, t.tm_year, t.tm_wday, tv->tv_sec);
         printf("RTC_getTime Seconds = %10d TimeStamp %s\n", mytime, asctime(&t));
         return 0;
     void RTC_init()
         int t;
         /* make sure clock is enabled */
         t = GbI2C_rtc_readReg(GbI2C_RTC_SECOND) & ~(0x80);
         GbI2C_rtc_writeReg(GbI2C_RTC_SECOND, t);
         /* make sure we are using 24 hour time */
         t = GbI2C_rtc_readReg(GbI2C_RTC_HOUR) & ~(0x40);
         GbI2C_rtc_writeReg(GbI2C_RTC_HOUR, t);
         _rtc_gettime = RTC_getTime;
         _rtc_settime = RTC_setTime;
    edited 2012-09-13 10:39
    I just tried the LMM mode, and it does not work. I also tried the XMMC mode, the program runs, but the printf() output is incorrect. So, I guess I am lucky that it works in CMM, at least I know that the RTC is working.
    I guess we have to consider what types of programs to use with the spin2cpp program; are programs that use their own i2c going to fail? What are the limtations of the spin2cpp program? Is propGCC team going to provide the drivers to support the different RTC units? If so, when will that occur? Lots of questions to be answered.
    I guess I have to rethink porting the dnaRTC program to the DNAxxx(filetest) program. I will try to look at the spin2cpp converted code and see if I can make it work using existing propGCC libs, but I can see a lot of problems that I may not be able to solve. I guess what I really need is a good, full use, I2C program example, to start with. I was using bits and pieces of existing code snippets, with no positive results. Any ides would be appreciated.
    Ray
    edited 2012-09-13 11:00
    As I mentioned basic_i2c_driver.c relies heavily on the code running slowly. .... There is nothing we can do about it.
    The official devices to be added for propeller-gcc and timing of that is up to Parallax (beyond what we have time add).
    I use a COG driver with a C wrapper for time sensitive devices like I2C. Here's my entire GameBaby code collection if you want to see what I've done. There are 5 different devices on the I2C bus handled by one PASM driver.
    edited 2012-09-13 11:05
    jazzed wrote: »
    The official devices to be added for propeller-gcc and timing of that is up to Parallax.
    It would be possible to put the basic_i2c_driver in hub memory and use waitcnt to make sure it doesn't run too fast.
    edited 2012-09-13 11:06
    David Betz wrote: »
    I'm afraid that's a source code problem that's up to the user to fix.
    edited 2012-09-13 11:07
    I'm guessing that your problem is due to the timing on the I2C bus. The basic I2C driver does everything in Spin, so there is plenty of time between clock and data transistions. When you convert it to C the code will run a lot faster, and the minimum setup, hold and clock durations may be violated. This may be why it works in CMM, but none of the other modes. Try optimization level zero to see if that makes a difference. Another thing you could try is to use the pasm I2C driver instead of the basic I2c driver. The method calls are the same between the two, but the actual bit twiddling is done in PASM instead of Spin, and it has more precise timing control.
    edited 2012-09-13 11:15
    The pasm i2c driver is in the OBEX at http://obex.parallax.com/objects/611/ . It's timing is set for 400 KHz with an 80 MHz clock. You can change it to a different speed by changing the value of DELAY_CYCLES. I wrote this object because the basic i2c driver was soooo slow. However, in this case we have the problem where the basic i2c driver runs too fast in C.
    EDIT: Set DELAY_CYCLES to 255 if you need to run at 100 KHz.
    edited 2012-09-15 09:36
    Attached is my latest RTC for the DNA board. This one compiles in CMM, LMM, and XMMC modes, and runs correctly. I tried attaching printc.c, but it messes up the screen print, not sure why that is happening. I also used pasm_i2c_driver, made the adjustments till it worked in all three memory modes. Let me know if their are some glaring problems.
    Ray
    edited 2012-09-15 14:06
    The attached program is a combined filetest.c, and the RTC program for the DNA-XXX board. I fits and runs in the CMM, and XMMC modes, but it no longer fits in the LMM mode. Need some suggestions as to where I should prune this to make it fit in the LMM mode, but I have a sneaky suspicion that it can not be pruned. So, let me know what everybody thinks, improvements, enhacements, make it more modular so works with other boards, or move onto something else?
    Ray
    edited 2012-09-15 18:23
    Ray, there's not much more you can do in LMM mode. The original filetest.c program just barely fits in LMM mode. I had to disable the mkdir and rmdir commands to get it to fit when using the mount routine. You could disable more of the file code to add other code, but I'm not sure if that makes sense. It's probably best to continue to work with the CMM and XMMC modes if you want to add more functionality.
    If you have a Spinneret board it would be interesting to get your code working on that card. It also has an RTC and SD card socket.
    edited 2012-09-16 03:40
    I do not have a Spinneret board, I am not sure, at this time, what I could possibly do with one, other than try my DNA-xxx program on it. Now if the Spinneret was WiFi ...
    I just burned my EEPROM with the DNA-xxx program, and I noticed the file size, in CMM mode was ~28KB, I also noticed that their is nothing in SimpleIDE to prepare and store a program on the SD card, at least not for the DNA board. I guess MGH Designs has to do some more support work for the DNA board. In the mean time is their a work around? If the DNA-xxx program grows any bigger, bigger than 32KB in CMM, I will have to store it to the SD card because it will not fit on the EEPROM.
    @Dave Hein, in the Burrows version of basic_i2c_driver, he added a couple of Methods, devicePresent(), writeLocation(), readLocation(). When I added those too the pasm_i2c_driver, and ran it through the spi2cpp, the resulting code, of pasm_i2c_driver did not work correctly in the C version. Was that just a fluke, or does their have to be something else done to pasm_i2c_driver to make those Methods work?
    Is their a C to C++ conversion program, just wondering what DNA-xxx would look like and run like in C++ mode?
    <edit> Just a thuoght, is there any way of using filetest and storing the created files to the EEPROM instead of/or the SD card? Then at least you could possibly use the filetest program on the QuickStart board. <edit>
    Ray
    edited 2012-09-16 08:35
    A while back jazzed provided me with an example program of how to use the <sys/rtc.h>. Below I worked his example into my UI format to run the program, runs as expected. Now I am trying to isolate the hour, minute, and second in a hh:mm:ss format for output. I am using the function below, but I am not getting what I want. I guess I do not understand how to use the time(), and asctime() functions correctly?
    Ray
    void Get_Time()
        time_t now;
        time_t tm_hour;  //Get the hour
        now = time(NULL);
        printf("%s", asctime(localtime(&now)));
        tm_hour = time(tm_hour);
        printf("%s", asctime(localtime(&tm_hour)));  //Display the hour
     * @file softRTC.c
     * This is the main softRTC program start point.
    #include <stdio.h>
    #include <time.h>
    #define BUFFERLEN 10
    void Help();
    void pause(int sec);
    void Set_Clock();
    int getdst();
    int prompttime(char *prompt);
    void Get_Time();
    int main(void)
        uint8_t buffer[40];
        waitcnt(CLKFREQ + CNT);
        printf("This is the softRTC.\n");
        Help();
        while(1)
            printf("> ");
            gets(buffer);
            if (!strcmp(buffer, "quit")) break;
            else if (!strcmp(buffer, "help"))
                Help();
            else if (!strcmp(buffer, "setclock"))
                Set_Clock();
            else if (!strcmp(buffer, "time"))
                Get_Time();
            else
                printf("Invalid Command!\n");
        printf("System Stop!\n");
        return 0;
    void pause(int secs)
        while (secs > 0)
            waitcnt(CLKFREQ+CNT);
            --secs;
    void Help()
        printf("Commands are: setclock, time, quit.\n");
    void Set_Clock()
        struct timeval tv;
        struct tm t;
        t.tm_isdst = getdst();
        t.tm_year = prompttime("Year")-1900;
        t.tm_mon = prompttime("Month")-1;
        t.tm_mday = prompttime("Day of the month");
        t.tm_hour = prompttime("Hour");
        t.tm_min = prompttime("Minute");
        t.tm_sec = prompttime("Second");
        tv.tv_sec = mktime(&t);
        settimeofday(&tv, 0);
    int getdst()
        int rc = 0;
        printf("Use daylight savings time [y/n] ? ");
        fflush(stdout);
        rc = (getchar() == 'y') ? 1 : 0;
        getchar();
        return rc;
        int rc = 0;
        char *endp;
        char buffer[BUFFERLEN];
        do
            printf("Enter %s: ",prompt);
            fflush(stdout);
            fgets(buffer, BUFFERLEN,stdin);
            fflush(stdin);
            rc = strtol(buffer, &endp, 10);
            if (endp == buffer)
                if ('\n' == *endp)
                    rc = 0;
                    break;
                printf("Invalid entry \"%c....\" Please enter a number.\n", *endp);
        } while (endp == buffer);
        return rc;
    void Get_Time()
        time_t now;
        time_t tm_hour;
        now = time(NULL);
    edited 2012-09-16 10:56
    Try these links.
    Generic time.h page that shows functions, etc...
    http://pubs.opengroup.org/onlinepubs/7908799/xsh/time.h.html
    Describes formatting parameters for strftime.
    http://pubs.opengroup.org/onlinepubs/7908799/xsh/strftime.html
    Here's some code from my LCD project.
    // using these headers
    #include <stdio.h>
    #include <time.h>
    void showTime()
      char timebuff[16];
      time_t now = 0;
      // now as zero says get current time
      now = time(&now);  // get number of seconds since Jan 1, 1970
      // "now" has time
      LCD_setTextXY(1,1);
      LCD_dec(now);
      // Show abbreviated "month day, year"
      strftime(timebuff,16,"%b %d,%Y",localtime(&now));
      LCD_printXY(timebuff,1,2);
      // %T is replaced by the time (%H:%M:%S).
      strftime(timebuff,16,"%T",localtime(&now));
      LCD_printXY(timebuff,14,2);
    edited 2012-09-16 11:16
    Change the line in Get_Time() that reads "tm_hour = time(tm_hour);" to "time(&tm_hour);". Your program should compile without a warning about an incorrect pointer, and it should run correctly. Note, the variable you call tm_hour is used to hold the number of seconds since Jan 1, 1970. You may want to change the name to "now" or "epoch_seconds".
