Are these stepper motors?
I was salvaging some dvd players today, these were the motors to control the laser position and open the tray. I really dont know alot about steppers besides there built to move in increments. They look like the steppers ive seen if floppys, I hooked them up to a coin cell they spun continously.
So im wondering if these are steppers they act like a regular motor, why couldnt you just rotate the shaft of a regular motor for a given time, will the stepper motor stop the shaft more accuartly or something? IDK the DC specs on these at allm but as long as they have some sort current amplification like a fet or chip, you can control the movement of these directly with a uController right? I mean you dont need a special chip to make it step right, that can be done in software?
When you turn the shaft of a stepper, you can often feel the shaft jump a little from one position to the other, often called cogging or detent.
How many wires do they have?
there probably plain motors from what u guys are saying. i dont feel any resistance when i twist the shaft. the continously spin when connected to a cr3025(mobo bips battery i think thats the number) and finally they all have two leads. I just hoped they were steppers since it seems like if a floppy needs them a dvd laser would
Steppers require at least 4 wires to connect.
3 Phase motors may also require 4 wires.
These two would be an area of confusion that might require more research.
