LCD Dead?
This is a follow up post to my previous one about the LCD on the PPDB. I have not done anything with the PPDB in months, and just started using it again. My LCD wont turn on for the life of me! I think it might be fried, is there a way to test that? I posted an image below to show how the board is hooked up:
Maybe I hooked the resistor up wrong? Please help me! Thanks!
Take a peek at this video:
Jim
I see you using a ribbon cable, so I am wondering how that might be?
Are you getting a blank screen (as in no power) or are you getting black blocks where the characters should be? If it is blank, it could be a lack of contrast. Black blocks are a possible indicator of a fried LCD (or too much contrast).
There is no real test to prove failure. But if you can get a good screen to initialize with the same software and wiring, and the suspect one won't - well that looks like a failure.
...so, what was the problem? Hmmm?
"Inquiring minds want to know!"
Maybe an IBM sign should be pressed into action.
Think, think, think.....
nrsmac
