TACHYON O/S V3.0 JUNO - Furiously Fast Forth, FAT32+LAN+VGA+RS485+OBEX ROMS+FP+LMM+++ - Page 11 — Parallax Forums
189111314109
    edited 2012-09-03 09:03
    There's been a few extra project pages added to the Intro links section.
    NEW - Project page links
    • PS/2 Keyboard interfacing - (WIP) Testing the PS/2 keyboard and what you can do too.
    • Characer LCD interfacing A full featured LCD driver - software contrast and brightness, big digits etc
    • Graphic LCDs Both the 128x64 and come other types
    • Serial devices Interfaces to common serial LCDs and devices
    • VGA Expanding a bit more on the driver - a how-to
    • Sound Fun both with bit-bashing, the counters, and then some WAV stuff
    • MMA7660FC ACCELEROMETER I2C This demonstrates have we can easily interface to a common I2C accelerometer
    • SD card interfacing Get right down to the metal with this. See what's "inside" a card etc
    • L6470 Microstepper Full code for this 3A RMS/winding 128-step chip (it's tiny)
    • H-bridge motor control
    • MC3208 8-channel 12-bit ADC
    • SILABS C2 Programming In-circuit programming of Silabs C8051F microcontrollers from the Prop
    • SAA1064 4-digit LED display This chip interfaces via I2C so you can have up to 4 chips without extra I/O
  • Brian RileyBrian Riley Posts: 626
    edited 2012-09-03 09:22
    With regard to the issue of a pull-up on the Chip Select for the SD card. For the SDPOLL word to work autonomously there must not be a pull-up.
    "A Tale of Two Platform Modules"
    The first, a Prop Platform USB board, pins 0 to 3 used, an SM 4 position 10K resistor pack pulling up all 4 lines, and worst of all the pull-up traces are mostly hidden by the socket! Maybe one of you guys with really young eyes and stead y hands could do it but the quarter inch of exposed traces (did I mention 'tiny') is nothing I want to tackle.
    So, I left CS pulled up. the "SD" command showed me my card data, but when I pulled it out, nothing happened. I typed "SD" and, correctly, I got "Card Error." I put the card back in, again, nothing ... again, typed "SD"and it displayed my card info.
    The second, Prop Plat Through Hole with a 'hacked'' microSD Platform Module (essentially cut the microSD out of a PP-USB), PP-TH has exact same Tachyon kernal and EXTEND and SDCARD. The board booted u p, typed SD and got card info. I then pulled the micro SD card got "Card Error", then re-inserted card and got card info.
    The hack suffered from the same placement and tiny traces as the PP-USB, soooooo ... got out my hot air rework station and removed the SM resistor pack and then using 3 10K 1/8th watt resistors used a spare set of holes to put pull-ups back onto CLK, DO, and DI.
    In the end with or without the pull-up on CS the Tachyon SD code works fine at its main job ... however, if you can have the CS pull-up removed you get some convenient benefits.
    1024 x 843 - 117K
    edited 2012-09-03 09:36
    If you are stuck with a pullup on the CS line then just modify CARD? by specifying the input for the #CD. Here is the before and after:
    [COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]'' Detect SD card presence - the CS line must not have a pullup on it (redundant and undesirable).[/FONT]
    [/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]pub [/FONT][FONT=Ubuntu Mono][B]CARD?[/B][/FONT][FONT=Ubuntu Mono]        ( -- flg ; Is SD card present? )[/FONT]
    [/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]        ON SDCS                        '' Force CS line low[/FONT]
    [/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]        .SDCS INPUTS                '' Float CS[/FONT]
    [/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]        .SDCS IN                        '' Is it still low or has it been pulled up (by the card's pullup)[/FONT]
    [/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]        OFF SDCS[/FONT][/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]
    '' Secondary brute force method
    [/FONT][/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]'' Detect SD card presence - use card detect switch and dedicated I/O[/FONT]
    [/FONT][/COLOR][COLOR=#000000][FONT=Arial][FONT=Ubuntu Mono]        #CD IN 0=
            ;[/FONT]
    [/FONT][/COLOR]
    BTW, that SDCARD code is the "old stuff" before I added the redirection ability.
  • PowersoftPowersoft Posts: 72
    edited 2012-09-03 12:31
    there's been a few extra project pages added to the intro links section.
    new - project page links
    • ps/2 keyboard interfacing - (wip) testing the ps/2 keyboard and what you can do too.
    • characer lcd interfacing a full featured lcd driver - software contrast and brightness, big digits etc
    • graphic lcds both the 128x64 and come other types
    • serial devices interfaces to common serial lcds and devices
    • vga expanding a bit more on the driver - a how-to
    • sound fun both with bit-bashing, the counters, and then some wav stuff
    • mma7660fc accelerometer i2c this demonstrates have we can easily interface to a common i2c accelerometer
    • sd card interfacing get right down to the metal with this. See what's "inside" a card etc
    • l6470 microstepper full code for this 3a rms/winding 128-step chip (it's tiny)
    • h-bridge motor control
    • mc3208 8-channel 12-bit adc
    • silabs c2 programming in-circuit programming of silabs c8051f microcontrollers from the prop
    • saa1064 4-digit led display this chip interfaces via i2c so you can have up to 4 chips without extra i/o
    try to download the saa1064 source, get some problems with the words byte and long.
    They are not seen by the compiler.
    I load the latest version of the bin and extension file.
    edited 2012-09-03 14:40
    Powersoft wrote: »
    A tachyon is never still, you haven't been keeping up with the thread! :) I mentioned way back...... a day ago.... that I wanted to allow variables to be entered the same way we do in Spin using comma separated lists. So you will have to compile the new kernel as there are other changes too.
    EDIT: I should mention too that you can just declare these in the normal way using VARIABLE & CVARIABLE but without a comma separated list
    edited 2012-09-03 20:10
    I've just tweaked the I2C routines to run at 400kHz with a cycle time of 36us for reading and writing. I know that there are PASM routines that run in their own cog or Spin routines that run very slow but this is just bytecode running from the main Tachyon cog.
    Here's a shot of the timing when performing a write and a read ($55 I2C! I2C@):
    What I'm wondering is does anyone have a need to run faster than this? Is anyone using 1MHz I2C?
    639 x 472 - 89K
  • nglordinglordi Posts: 114
    edited 2012-09-03 21:19
    Peter:
    There appears to be a bug in PINS? (current version of EXTEND) which is not present in earlier versions.
    Results for pins 16-31 mirror those for pins 0-15.
    NickL
    edited 2012-09-03 21:32
    nglordi wrote: »
    Peter:
    NickL
    Not sure what is happening there as I just did a quick check and got:
    PINS?
    i----------u----------i
    P00 <-- 1     1 --> P31
    P01 <-- 1     1 <-- P30
    P02 <-- 1     1 --> P29
    P03 <-- 1     0 <-- P28
    P04 <-- 1     1 --> P27
    P05 <-- 1     0 --> P26
    P06 <-- 1     1 --> P25
    P07 <-- 1     1 --> P24
    P08 <-- 1     0 --> P23
    P09 <-- 1     0 --> P22
    P10 <-- 1     0 --> P21
    P11 <-- 1     0 --> P20
    P12 <-- 0     0 --> P19
    P13 <-- 0     0 --> P18
    P14 <-- 0     0 --> P17
    P15 <-- 1     0 --> P16
    i---------------------i ok
    So that doesn't look mirrored at all. If you downloaded from the webpage version just make sure that you refresh it beforehand as you may have a stale copy. Just in case...
    [COLOR=#000000][FONT=Ubuntu Mono]'' List out each of the Prop's I/O pins & their direction)[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]pub [/FONT][/COLOR][COLOR=#000000][FONT=Ubuntu Mono][B]PINS?[/B][/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    CR ." i----------u----------i"[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    P@ DIRA COG@    ( port dir )[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    #16 0 [/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]      DO[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]      CR ." P" I $20A .NUM DUP I MASK AND [/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]        IF ."  -->" ELSE ."  <--" THEN [/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]      SPACE OVER I MASK AND 0<> 1 AND .[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]      5 SPACES OVER #31 I - MASK AND 0<> 1 AND . [/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]      DUP #31 I - MASK AND[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]        IF ."  <-- P" ELSE ."  --> P" THEN[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    #31 I - $20A .NUM[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]      LOOP[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    CR ." i---------------------i"[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    2DROP[/FONT][/COLOR]
    [COLOR=#000000][FONT=Ubuntu Mono]    ;
    [/FONT][/COLOR]
    edited 2012-09-03 23:20
    I've just tweaked the I2C routines to run at 400kHz with a cycle time of 36us for reading and writing. <snip> What I'm wondering is does anyone have a need to run faster than this? Is anyone using 1MHz I2C?
    400 kHz is a pretty decent speed even for a PASM implementation. For Forth, it's very impressive. Personally, if I needed anything faster, I'd use SPI. It seems a lot more robust for high speed use.
    edited 2012-09-04 07:10
    Powersoft wrote: »
    when i understand you right is 8 bit enough. It wil used for a motor controller
    Peterbdo you have a pwm example in tachyon?
    edited 2012-09-04 07:36
    Thanks. The version I was using had the phrase ' #31 I - " missing in two critical places.
    NickL
  • D.PD.P Posts: 790
    edited 2012-09-04 16:51
    Wow, I go on vacation for a week and 4 new pages of Tachyon "news" are posted. You are right Peter Tachyons never stop moving. Look forward to catching up with everything.
    edited 2012-09-04 17:10
    D.P wrote: »
    I do have some I2C RTC code as well with standardized interface so you can read and write stamps or strings without regard to the chip but I want to connect to a Spinneret I've got here and interface to that chip too. There's a 1-wire page and some other ones that are alluded to in the Intro page that will go up as soon as I finish scratching myself.
    edited 2012-09-04 17:15
    nglordi wrote: »
    NickL
    You know, it's quite possible that you had a snapshot of a page that I was editing because that only existed for the brief moment it took to check and fix. I try to avoid that however for this very reason and I either make small changes in a text editor before pasting or encapsulate my test code in curlys in the online document to avoid transients. So it you do get an error during loading then go back and just refresh your webpage copy.
    edited 2012-09-04 17:27
    Powersoft wrote: »
    I will try to fit it in today in my schedule of forum browsing, posting, and scratching myself :) (but mostly real work)
    Do you need this multichannel as it would make sense and what frequency?
    edited 2012-09-04 17:49
    For many people familiar with Forth they know that things are done a certain way and Tachyon doesn't always do it the same. Even in little things such as DO.. LOOP it's conventional wisdom to push loop parameters onto the return stack (I cringe) and remove those after the loop exits. Also LOOP has a branch address compiled after it so that it can branch back to the start of the loop. The other problem is that the stack index is not easily accessible outside of the loop but has to be passed explicitly which is more junk on the data stack.
    IDEA:
    So in Tachyon we have a separate loop stack used for DO..LOOP and FOR..NEXT parameters which do not mess with the return stack and allow easy direct access to parameters. But there is still the branch address used by LOOP and NEXT which seems both inefficient and can slow down a fast loop. So I got to thinking what if we include the branch address as part of the loop parameters that get pushed onto the loop stack when we first enter the loop with DO, ADO, or FOR so that there are 3 not 2 parameters (as in DO)? This way when a branch has to be taken it can read it directly from the loop stack in cog RAM and snap back to the start of the loop in an instant without the slow hub access required to read the branch normally. The same would go for repeating structures such as BEGIN UNTIL as well.
    Just thought I'd share this one with you as I'm always looking at ways of making Tachyon and Forth better, both from a programming perspective and from a run-time efficiency perspective.
    edited 2012-09-04 18:31
    Maybe add a third stack and explore all that matrix and stack frames stuff they talked about?
    http://www.ece.cmu.edu/~koopman/forth/rochester_90b.pdf
    edited 2012-09-04 18:46
    Actually that would make it a fourth Forth stack :) I already have the DATA, RETURN, and LOOP stacks. Already I'm looking at putting the loop branch address onto a BRANCH stack so that then would make it five stacks! Well, whatever works as long as it doesn't make it complicated from the coding perspective, just simpler. I've started coding a new version of Tachyon that has almost zero overhead when looping in DO..LOOPs etc. I also want to extend that to repeat branches as well but I will test out the looping shortly.
    BTW, Tachyon also uses 4 or 5 cog registers (COGREG) for parameters in certain functions such as SPI, SD etc where there is a lot of repetition and this helps keep the data stack small and tidy.
    Tachyon V2 stacks:
    DATA for pertinent data parameters (not using it for junk)
    RETURN only for return addresses (and the occasional fudge)
    LOOP where index and limits for looping are placed
    BRANCH for branch addresses for looping and repeat structures
    LOCAL for local variables
    EDIT: I think Tachyon is now 2 months old a couple of days ago, time for it to evolve!
    edited 2012-09-04 21:07
    Two channels will be fine, because the most motor controller shields for the arduino (I use the ASC board) can handle 2 motors.
    I think a frequency of about 500 HZ will be fine (adjustable?), and the range of manupulation the pwm may be 0..255
    Cheers,
    Jan Kromhout
    Hellevoetsluis-NL
    edited 2012-09-04 21:29
    Well I have been playing with Tachyon V2 and looping is like it's slid on rails, I'm getting figures of 400ns loop overhead compared to 800ns (average due to hub access jitter) in V1. As a side bonus I no longer need special words to compile loops, you know DO compiles a (DO) bytecode normally and leaves stuff on the stack for LOOP to work with and compile a (LOOP),<branch>. Yep, no longer need those special word and the loop code is more compact, cleaner, and twice as fast. The same will go for BEGIN..WHILE..REPEAT structures etc.
    @Jan: Wait your turn! I'm busy with V2! :)
    I will try to get around to it soon.
    edited 2012-09-05 19:25
    I've made a decision to hold Tachyon V2 until I have done a bit more testing and tweaking so as to avoid all the "this doesn't work" when I am still testing and deciding what to do. The kernel is running very well and I made some decisions in optimizing it. For starters besides the new stacked looping used in DO...LOOP +LOOP FOR..NEXT I have also implemented stacked conditional looping with <BEGIN...AGAIN> or UNTIL> and added a POPMARK word so that a forced exit can adjust the MARKER (branch marker) stack. The reason I did not replace the conventional conditional looping was that it does have uses and there may be some user code that may not take into account the MARKER stack and break it.
    So I've had to squeeze a bit more into the cog kernel where there was absolutely no room before so now the bits are more compressed :o I managed to find some operations or parts thereof that could be moved to the hub kernel (bytecode) and removed some redundant registers etc. The 16-bit calls (vs 8-bit indexed) have not been used yet as everything so far including my applications have not exhausted the call vector table but I will be pushing it so that these limits are tested. This also means the expansion of the dictionary and word help functions into EEPROM or other non-volatile storage such as SPI FLASH or SD.
    I'm also thinking of implementing a fast serial download feature a bit like PropForth in that a Tachyon cog just processes the input stream and strips out all the redundant spaces and comments etc (about 50%) and buffers this in available RAM which the main Tachyon cog can then process at it's speed which most of the time is fast. This would remove any need for line delays as there is no handshaking although I wish that all terminal emulators supported XON/XOFF properly. So the TACHYON word that I use at the start of a source code file will trigger the fast load automatically. BTW, the TACHYON word is just there to make sure that you don't try to load it on another Forth system and also to reset error counters etc.
    There's also context switching support for changing the REG base for any Tachyon cog so that it can have it's own local variables etc. If anyone wants a copy to play with V2 in the meantime and perhaps report bugs (without expecting anything) then please PM me for a link.
    edited 2012-09-06 07:18
    Peter,
    What's the story on "=IF" and/or "EQIF" ... it looks like its there but it isn't. The other day you mentioned LOOKUP and LOOKDOWN as CASE substitutes . Do they exist?
    I would like to take a whack at V2. Please send the link to my regular email address ... TNX
    edited 2012-09-06 07:40
    Peter,
    Since we have to work with the Spin tool we also need to avoid reserved names such as LOOKUP so internally it's known as VECTORS. However I don't have a LOOKDOWN yet although it's probably no problem and still checking out a few different scenarios to see how I can make a really useful (and efficient) CASE structure. Will send you the link shortly. The EQIF was removed as there are only so many bits in a long and so many longs in a cog and we are always a "bit" short.
  • D.PD.P Posts: 790
    edited 2012-09-06 22:22
    Trying to get version 1.1 working with the SD card on the Prop BOE I have added this to SDCard.fth:
    : PBOE '' Prop BOE
    $19171816 SDPINS
    #25 SDCS '' SD Card chip select
    #23 SCK '' SD Card clock
    #24 MOSI '' SD data in from Prop
    #22 MISO '' SD data out to Prop
    Based on this from the Prop BOE docs
    P22 MicroSD card DO (data out)
    P23 MicroSD card CLK (clock)
    P24 MicroSD card DI (data in)
    P25 MicroSD card /CS (active-low chip select)
    Just not sure if this is correct.
    edited 2012-09-07 10:08
    JonnyMac has contributed an enormous amount of code to the Parallax community. One of my favorites is "jm_servo8-ez.spin" ... it is what its name implies ... simple and easy background servo pulse driver all in spin. The counters/timers of the prop are hidden behind the WAITCNT commands. Its a quick, easy and CLEAN way to get servos up and running on a prop.
    I started my usual way by transcribing from spin to TF ... I got a clean load in two tries under kernal rev120905.0000.. I sat back and looked at what I had and GAWD! ... it sure was ugly and I couldn't get the background task to kickoff. After some patient help from Peter I have it going and documented and available for public consumption.
    I compiled the code under kernel 120905.0000 with and EXTEND.fth newer than 120904. I ran it on a PropBOE with a couple of GWS servos I had hanging around. Any problems let me know.
    Thanks, Jon!
    Attachment not found.
  • JonnyMacJonnyMac Posts: 9,287
    edited 2012-09-07 10:21
    Thanks, Jon!
    My pleasure -- and thanks for the kind words. I am still in the struggling stages with Forth, and as this is the Halloween season and I'm very busy writing code for my customers, not sure how I'll fair. The key for me -- as I often tell my customers -- is to create a real project. It's neat to see a translation of the code, though I dare say I don't know how you got from point a to point b....
  • D.PD.P Posts: 790
    edited 2012-09-07 10:44
    Thanks, Jon!
    Brian do you have SDCard.fth running with the PBOE? If so please share if possible.
    EDIT: Now that I found version : SDCARD.fth ." SD CARD Toolkit - 120908.0400 is does have the PBOE word and I got the bitmask correct but I still get a "SD Card Error" when attempting to use the SD word?
    edited 2012-09-07 21:03
    D.P wrote: »
    NOPE! It won't work on any of my uSD cards. I also checked Mike Green's PropBOE Basic source code for pin numbers as well as loaded the code and verified the card worked.
  • D.PD.P Posts: 790
    edited 2012-09-07 23:33
    Okay, thanks for the effort. I'll just be patient and wait until the SD tool kit is further along in Tachyon.
    edited 2012-09-08 02:23
    D.P wrote: »
    I just added the BOE parameters that were handed to me but I double checked the schematic and entered the pin numbers individually using the SDCS SDK MOSI MISO words and had a look at the long it generated and it was different from what was supplied. So the definition has been corrected.
    Before it was: $19171816 SDPINS
    but after entering:
    #25 SDCS
    #23 SCK
    #24 MOSI
    #22 MISO
    ok
    I read the result as
    sdpins @ .LONG 17181619 ok
    So the correct long is: $17181619 SDPINS
