Just curious, how big is the actual piece of wafer inside a Propeller DIP?
Oldbitcollector (Jeff)
For some reason, this occurred to me today. Would a cut-down 24pin DIP be possible?
(See attached)
Jeff
(See attached)
Jeff
When you get back from the shop: Where are you going with this?
Btw: like the new part number. Missed that at first glance.
http://forums.parallax.com/showthread.php?134596-Lobotomized-Prop
You could certainly cut it down, but need the I2C boot pins. Also you can get 0.6" to 0.3" width converters, so something like a DIP-24s with 16 GPIO could me made (losing P8-23)
and the result...
It's fortuitous that the VSS and VDD pins line up where they do!
(Yes, it's gimped.)
Yes! They can be found at your friendly Parallax Store
If space is the concern you can go smaller using the other packages and still have full pinout.
C.W.
But did it run?
Duane J
Doc..see post #11
10,000 PDIP's in a "Hello Kitty" motif would sell like hotcakes!
