Just curious, how big is the actual piece of wafer inside a Propeller DIP? — Parallax Forums
edited 2012-08-29 17:18 in Propeller 1
For some reason, this occurred to me today. Would a cut-down 24pin DIP be possible?
(See attached)
Jeff
    edited 2012-08-28 21:51
    No idea how big the chip is but my bet is that you could take a hacksaw to the DIP Prop and remove 6 pins from the tail end and still have a working Prop.
    edited 2012-08-28 22:01
    The die is 7.3mm x 7.3mm, as I recall.
    edited 2012-08-28 22:03
    From Chip, Propeller-Die-Photo, square, 7.28mm on a side.
  • Roger LeeRoger Lee Posts: 339
    edited 2012-08-28 22:06
    Jeff, be careful with the saw.
    When you get back from the shop: Where are you going with this? :lol:
    Btw: like the new part number. Missed that at first glance.
    edited 2012-08-28 23:20
    Right now, Jeff will be measuring from the center of the chip half of 7.3mm and you know, I can hear sawing in the workshop...
  • TubularTubular Posts: 4,740
    edited 2012-08-28 23:32
    Yeah it's certainly a nice big rainbow colored thing, as I found out using the mill. Here's the thread
    http://forums.parallax.com/showthread.php?134596-Lobotomized-Prop
    You could certainly cut it down, but need the I2C boot pins. Also you can get 0.6" to 0.3" width converters, so something like a DIP-24s with 16 GPIO could me made (losing P8-23)
    and the result...
  • SRLMSRLM Posts: 5,045
    edited 2012-08-28 23:33
    If Parallax offered a Propeller Die poster, I'd buy it. (and T-Shirts, and mugs, and ... , and ...)
  • pedwardpedward Posts: 1,642
    edited 2012-08-28 23:46
    I counted the pins in Tubular's photo, and it's possible to make a DIP-24 version without disturbing the die. For safety, just make sure the border is the same on the cut side as the notch.
    It's fortuitous that the VSS and VDD pins line up where they do!
  • PaulPaul Posts: 263
    edited 2012-08-29 05:33
    I posted something similar a couple years ago. Probably not practical for a production system.
    (Yes, it's gimped.)
    350 x 281 - 20K
    679 x 326 - 37K
    edited 2012-08-29 06:11
    Yes! They can be found at your friendly Parallax Store :)
    edited 2012-08-29 07:10
    Considering that the same die would be used, there would be very little cost advantage, so I'm not sure I see why it would really be needed.
    If space is the concern you can go smaller using the other packages and still have full pinout.
    C.W.
    edited 2012-08-29 07:28
    It might be more expensive, but there is the SPIN STAMP....
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-08-29 07:35
    Paul wrote: »
    (Yes, it's gimped.)
    But did it run?
    Duane J
    edited 2012-08-29 09:36
    Doc..see post #11 :)
    edited 2012-08-29 11:41
    Thinking about buying 10,000 dies from Parallax and having them custom packaged? ;)
    10,000 PDIP's in a "Hello Kitty" motif would sell like hotcakes! :)
